305tbi to 383 Carbed
Old Dec 11, 2001 | 11:31 PM
AZ88Maro's Avatar
Ok guys next semester in school i want to do a 305 to 383 swap. I have the block and the stroker kit will take car of the bottom end. I plan on replaceing cam, heads, intake, carb (swap from tbi), air filter, and distrubitor with after market stuff. Is there any thing i have to switch out to make this fit. Is there anything i SHOULD swap out.
Old Dec 12, 2001 | 08:31 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i think you named it all. just replace the entire motor. you'll be all set. what do you plan on doing as far as fuel pump/fuel lines? make sure you think about that. also, you will need a kit to hook up your throttle and TV cable (assuming you have an automatic).
-brian
1991 Camaro RS
GMPP 350 HO crate engine w/TBI
Homepage z28boy@twcny.rr.com AIM - "Z28 Boy"
Old Dec 12, 2001 | 09:34 AM
Phantomht's Avatar
Car: 84 Camaro Berlinetta
Engine: 377ci standard bore 383
Axle/Gears: 4.56
Just did a 2.8L >> 377ci swap, although mine was carb to carb it was still different, went to salvage yard for V8 throttle cable and bracket, bought a NEW TV [25$] cable cause that isnt something you want to be replacing more than ONCE [what a be-otch], specially if you have solid motor mounts like i do.
Howard
B & H Racing
http://home.earthlink.net/~phantomht/
Old Dec 12, 2001 | 01:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless you have paid big bucks for your rotating assembly, you're going to need an externally balanced harmonic damper and flexplate/flywheel. This will likely drive a starter change as well.
Are you doing anything to the exhaust?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
