best fuel option?
Old Mar 10, 2010 | 02:44 PM
breamrules's Avatar
best fuel option?
I am doing a a 305 carb to 350 carb swap on my 1982 se. The 350 block was originally tpi. This should be straightforward but the 350 does not have a completed fuel pump rod provision so I figure I am going to have to run a pump with a fuel pressure regulator. Should I run an in tank pump? Is my tank even set up? Or should I just mount an inline pump and cut into the fuel line? What is the most reliable option? Any advice is appreciated.
Old Mar 10, 2010 | 03:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An in-line pump would be the easiest. They certainly are easier to install and replace, and are reasonably reliable.
Old Mar 10, 2010 | 03:33 PM
breamrules's Avatar
Re: best fuel option?
ok. The 350 has the 416 heads (ported) and a zz4 cam. I just wanted something fun for the streets. Any recommendations on pump and/or regulator?
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
