What else do I need for installation????
Old Dec 13, 2001 | 11:16 PM
CamaroX84's Avatar
Well, I'm set on replacing my LG4 in my 84 Camaro with the GM Fastburn 385. The crate motor comes with: block, rotating assembly, balancer, flywheel, heads, cam, intake manifold, water pump, and distributor. Will all the brackets from my LG4 work (alternator, A/C compressor, etc.)? Will it all swap over? What else do I need to make the swap happen? I know I need a carb and a timing chain. Anything else? Any help would be greatly appreciated. Thanks.
Old Dec 14, 2001 | 01:02 AM
Joshua Leslie's Avatar
sounds like you have it all covered...
I believe that the acceory holes on those heads are universal, so they should work with your brackets.
Just be sure to keep everything from the old motor until you get the new one in.
I think the motor comes assembeled...the timing chain should already be installed.
Old Dec 14, 2001 | 11:37 AM
CamaroX84's Avatar
Thanks for the reply. What about a fuel pump? Does it come with one? If not I guess I'll need to buy one since the LG4 one isn't gonna cut it. Thanks again.
Old Dec 18, 2001 | 01:25 PM
mcconahay37's Avatar
You will need to get a fuel pump. Everything else bolts on just fine. Before you take the brackets off your LG4, take pictures or draw pictures of how they go together. Otherwise, it'll cost you more time than you had planned on. Trust me on this one Also, if you haven't done it yet, you REALLY need headers and a good exhaust for that fastburn motor, or you'll never reach it's 385 horse potential.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
