v6/5 speed swap
Old Mar 13, 2010 | 01:16 PM
craveman85's Avatar
v6/5 speed swap
i have an 85 carbureted trans am and would like to put a v6/5speed in it for dirt racing. anyone know what i would have to do to put the engine in there and get it to run right. ive never done anything fuel injected before and the motor must appear stock. i was thinking of a 3.1 and a 5 speed. thanks.
Old Mar 16, 2010 | 09:48 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: v6/5 speed swap
work out the differences for the fuel injection, youll need a fuel pump, better to just swap over the whole efi system from another car
Old Mar 17, 2010 | 09:02 AM
Pocket's Avatar
Car: 91 Trans Am
Re: v6/5 speed swap
Find a 730 V6/5spd ECM and tune VATS out, then either swap the engine/dash harness in from a 90-92 bird or buy a 90-92 stand alone TPI harness and leave two injector connectors laying free. The stand alone harness will allow you to keep everything from your 85 TA. Use an inline 4 pulse cable to electric VSS to generate the signal for the ECM without compromising the stock 85 cable speedo
You will also have to update the sender and fuel lines for high pressure EFI
3.1 V6 and 90-92 TPI are very similar as far as control systems go
Old Mar 17, 2010 | 10:22 AM
craveman85's Avatar
Re: v6/5 speed swap
hmm quite a bit of crap to build a dirt car.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
