First Engine Swap: Need some Advice
Old Mar 10, 2012 | 01:29 PM
  #51
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Re: First Engine Swap: Need some Advice
Originally Posted by InfernalVortex
you need to go ahead and do it. You need to know what your oil pressure is on a newly built engine anyway.
That hole may have a plug, or it may just be open. So you need to be sure. If it has a plug it may be kind of a pain in the *** to get it out, though.
Do you mind sharing what the casting numbers are on your cylinder heads?
There has to be a plug in there, not sure how I would get it out. Would this cause my engine not to start with no oil pressure switch sensor hooked up, initially it ran, but now i'm not getting fuel from my injectors and wondering if this might be the problem. I've heard this could tell the ecm to shut the fuel pump off.
Old Mar 10, 2012 | 03:18 PM
  #52
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Ok, this is what I did...
I drained my oil, took out that plug and put in my Oil pressure sensor, filled it back up with oil, hooked up the battery.
It started, but was running rough, then it died, and would not start again and injectors werent spraying.
Any ideas.
Old Mar 11, 2012 | 11:24 PM
  #53
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Problem solved, car is running, thanks for the help guys
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
