cam break in
Old Mar 21, 2010 | 07:28 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
cam break in
what is the easiest and the best way to break in a cam, how do you go about breaking one in?
Old Mar 21, 2010 | 07:34 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: cam break in
is it roller or non-roller?
Rollers are easy
I had a mechanic tell me about my roller cam once.......did you start it? It's broken in
If it's not a roller cam, you'll need to follow the procedure of running it up to X RPM for 20 Mins and so on
So, is it a roller cam?
Old Mar 21, 2010 | 07:50 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Re: cam break in
no its not a roller...ive herd people say that all you need to do is drive it around and others say to bounce it for 20 min or so
Old Mar 21, 2010 | 08:00 PM
Gregzz4's Avatar
Re: cam break in
I'm looking for what you want to hear, but in the meantime I used this stuff
I can't find the receipt for the stuff I used, but this is the # I found on another site
GM part #12345501 additive
Old Mar 21, 2010 | 08:06 PM
Gregzz4's Avatar
Re: cam break in
Ok, I'll nevermind looking around
After re-reading your post I see you are on the right track
Yes, you 'bounce' it around for about 20 Mins, but you have to keep it steady and between 15-2500 RPM
Don't rev it and don't idle it
Be nice and gentle with it
Get it running and take it to the RPM range and hold it there
Never hold it at the same RPM for too long, change it a bit up and down for the 20 Mins but try to just change the RPM and hold it where you changed it to
It's not that picky of a process, but I am
Then you drive it very gently for the first 500 Miles and do an oil change
Jorlain
Oct 8, 2015 01:57 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Ranbo108
Sep 9, 2015 12:20 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
