305 to 350 plus some
Old Mar 27, 2010 | 02:28 AM
jeramiahjames's Avatar
Car: 89 Pontiac Firebird Formula
Engine: 305 TBI
I have a 89 Firebird Formula with a 305 TBI in it. I am looking to put in a 69-80 (based of the block casting number) 2 bolt main 350 bored .30 over with a mild cam. This motor was originally carburated.
Now what I am wondering is what heads would be better for this motor swap (the 305 or 350 heads or other).
If the throttle body intake from the 305 would bolt up and work with the 350.
What injectors would be best? Would the Knock sensor and ESC module be different than the ones mentioned in the thread (How to: 305 To 350 swap... everything you need to know)?
I know that modifications would have to be made to the chip. Any information on what might need to be altered?
Anything else that anyone has to offer about this.
I appreciate any help that anyone has to give.
Jeramiah
Last edited by jeramiahjames; Mar 28, 2010 at 12:45 AM. Reason: some clarification
Old Mar 29, 2010 | 09:06 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 to 350 plus some
The first step is to give us the casting numbers of the heads. You have to remove the valve covers to find the casting numbers. Don't buy anything until the heads issue is resolved.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
