502 or 350?
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
502 or 350?
cant decide between a 502 or 350 for my 87 if anyone knows anything that might help me please let me know
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
Re: 502 or 350?
It kind of depends on what type of tranny and rearend your using im gonna guess its a stock 7.5 rearend or 9 bolt and 700-r4 tranny.........if thats the case then I would say a medium built 350ci would be good. I believe the rearend would pop under the stress of a 502ci....NOT saying the 350 wouldnt do it....Question is what are you building it for?
Car: 92 rs,70 chevelle ss,86 buick gn
Engine: 305 tbi,402 bb,turbo v6..what else?
Transmission: 700r4,muncie 4 speed,stock
Axle/Gears: 3.73,4.11,stock
Re: 502 or 350?
100% agreed
putting a big block in a third gen?
probley alot of fabricating there...
ive seen it done before though
also bbs are better off in full body cars
i would stick with 350
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 502 or 350?
These 2 members threads chronicle Bigblock swaps:
booboosean & The Devastator. Search the names & you'll find some great reading with tips & tricks!! They each used different headers & exhaust.
There are 2 members who have Bigblocks, 1 I know is a drag car, IDK the other. Alky IROC has a Bigblock used for drags. I BELIEVE but not sure, Atilla The Fun has a Bigblock..??..
Bigblock in our future also!!...
Axle/Gears: stock
Re: 502 or 350?
Axle/Gears: stock
Car: 87 GTA
Re: 502 or 350?
Street or drag? Federally, it'll NEVER legally pass any states inspection. Not saying you can't get around the law, but......
Axle/Gears: stock
Car: 87 GTA
Axle/Gears: stock
Axle/Gears: stock
Car: 87 GTA
Re: 502 or 350?
That is weird.
Although it does look like you could do a BBC (if i understand you right) that doesn't exactly make it legal to do. But it also sounds like WI has nobody to enforce Federal Law.
But why put a heavy BBC in? Just stroke a 350 to a 383.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 502 or 350?
Some of yall need to come down to a free state like Florida. If it has a VIN, you can register it. There are no inspection, no emissions, no nothing. I could put a semi truck engine in a VW bug if I want to.
Me personally though, I would run a good small block. The big block is definetly cool, but the small block weighs less and you can build a small block that will be plenty fast for the street. If it was a dedicated track car then thats different. But if your also building a car for the wow factor, then a big block would be cool to see under the hood.
Axle/Gears: stock
Re: 502 or 350?
No yearly/bi-yearly inspections? Just pay your registration fees & your done every year?
That is weird.
That is weird.
Axle/Gears: stock
Re: 502 or 350?
yea we dont have inspection in wisconsin either. and i want to do something that not many people have
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 502 or 350?
I'd much rather have a mild 502ci/500hp in my street car than a high-stung and finiky 383ci/500hp. Just my 2 cents.
Axle/Gears: stock
Re: 502 or 350?
is the 502 long block?
how much did you say again?
Car: 86 iroc-z
Engine: 305 tpi
Re: 502 or 350?
Axle/Gears: stock
Car: 86 iroc-z
Engine: 305 tpi
Re: 502 or 350?
I personally dont think 3000 bucks would build your motor, upgrade to a stronger rearend and convert your car to a standard...The rearend alone would cost half or more if you aftermarket....But to build a small block that would be a different story....But hey Its your car do what you want to do.
Big Power = mo money
Axle/Gears: stock
Re: 502 or 350?
Engine: 5.1 4bbl
Re: 502 or 350?
a 12 bolt Moser rear end will cost about 2800 dollars...
Axle/Gears: stock
Re: 502 or 350?
Putting in a 502 is no different than a 396 or a 454. Externally they are the same.
Car: 86 iroc-z
Engine: 305 tpi
Re: 502 or 350?
This is a good deal im actually putting a ford 9 inch in a 68 camaro... but you will need to get it cut down and have your brackets and etc welded on to the 9 inch and will need to buy axels for a thirdgen to fit it, or you might get lucky and get the axels that came with some of the rearends that can be resplind when you have them cut down............. but your still looking to spend close to 1500 or more for parts and labor.
Re: 502 or 350?
Plus you dont know the condition of the axle. It may need to be rebuilt. When I put the 9" in my car I thought I was going to save money by buying a Moser housing and axle package, then getting the center chunk from a junkyard. After having new bearings put in and having a Detroit Locker put in, it would have cost about the same to just buy a complete rear end.
Axle/Gears: stock
Re: 502 or 350?
Engine: 5.1 4bbl
Axle/Gears: stock
Re: 502 or 350?
There is no way to know. Some people have gotten extremely lucky and gone into the 10's on a stock axle and some people brake them with stock motors. I personally wouldn't even think about putting a big block, or anything with over 400 horse, in front of a stock axle.
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Car: 87 GTA
Car: 1986 Trans Am
Engine: 5.0
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 502 or 350?
Originally Posted by jfroh1992
and i just like bbs more than sbs
Engine: 5.1 4bbl
Axle/Gears: stock
Engine: 5.1 4bbl
Axle/Gears: stock
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 502 or 350?
I've been looking at this thread for days, trying to put my finger on what it was that bothered me. I've got it now, even if it is too late. But if you can afford a 502, then you can afford a 416-cube LS3 stroker with good heads, and boost. Way more hp than a 502, plus clean emissions for when the lawws change, plus at least triple the MPG, plus better handling and braking due to the 300+ pound weight savings.
Transmission: 4L80E/4L80E
What has bothered me about this thread is the 502 and 350 are so vastly different, that you can't possibly have an intended use in mind, or an understanding of the task ahead, if you are considering them both.
Engine: 5.1 4bbl
Re: 502 or 350?
I lol'ed at that... only a few F-Bodys are gonna be on the road when this comes into effect... I keep telling everyone in every post where they're asking about swapping engines... you have got to be ready for the future, because these laws will take effect sooner rather than later... I mean you don't lose tremendous amounts of HP if your car is running clean... I thought well as long as your A/F mixture is set appropriately and I'm not being fumigated by your car's exhaust at a stoplight it be good, but now that I've been catching up on reading about pollutants that are produced as a by product of combustion, well I guess I am all for improving emission laws, I would just expect them to lower their expectations of a 20+ year old car... DAMN POLITICIANS...
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 502 or 350?
I disagree with the first half of what kid just posted. Because either one would be more fun on the street than a 305. But in this scenario, the 502 isn't that much more fun unless you invest in stronger trans and rear, plus everything necessary to make it hook. The chassis and suspension stuff, not just tires.
Axle/Gears: stock
Re: 502 or 350?
i can only afford the 502 because someone i know wants it out of his garage
Axle/Gears: stock
Re: 502 or 350?
the reason im considering these motors is because i can get them both pretty cheap
