1988 400 sbc swap
Old Apr 15, 2010 | 07:58 PM
Toomanycars's Avatar
1988 400 sbc swap
So I have a 1988 camaro base model .. It came stock with the 2.8/700R4 combo.. I have a SBC 400 thats geting built to go infront of a 700R4 .. so on to the pics..
Old Apr 16, 2010 | 12:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Keep us up on your progress.
Old Apr 19, 2010 | 09:19 AM
Re: 1988 400 sbc swap
well the motor is a 71 400 4bolt main .. Its been bored 30 over . Stock botom end with trw forged pistons ..I plan on useing a TPI setup on top with a set of EQ heads .. and tossing in a paxton super charger for the hell of it .. the cam is yet to be determined but it will be a full roller setup..
Old Apr 19, 2010 | 10:43 AM
the phoenix's Avatar
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Welcome and congrats on the swap!
I just finished up he swap of replacing a similar 305 with a 412. Enjoy!
Old Apr 19, 2010 | 11:31 AM
e0moser's Avatar
i just did this swap with a 406. Make sure your 406 has all 3 starter bolts. if it doesn't have it drilled and tapped before you put it in
Old Apr 23, 2010 | 07:18 PM
I am pulling the 700R4 out of an 305 RS at my local yard .. should I keep the 3.42 rear end thats in my car now or swap in the rear end out of the donor car..
Old Apr 23, 2010 | 07:42 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
whats rear does the donor have? maybe i missed it.. 3.42 LSD behind a 400 sounds pretty mean off the line.
Old Apr 23, 2010 | 07:44 PM
not sure on the RS rear end i have to figure out what year it is and check the codes to find out
Old Apr 23, 2010 | 07:46 PM
Ca[maro]88's Avatar
being an rs i doubt its a posi. and its more than likely a 2.73 gear. is your 3.42 a posi?
Old Apr 23, 2010 | 07:49 PM
its the stock rear for an 88 v6 car.. not sure .. I only say its a 3.42 because all the info says thats the only gear ratio available in the v6 cars in 88.. I have a few other projects that im finishing up so i havent really dove into this one yet just rounding up parts ..
Old Apr 23, 2010 | 07:52 PM
Ca[maro]88's Avatar
ahh ic. well id just see what you got before you start gettin other stuff. if indeed its a 3.42 posi rear end then its the best rear that came with these cars besides the 9 bolt.
Old Apr 24, 2010 | 09:55 AM
I know this is a camaro site but figured I would show ya some of my other projects ..
http://www.v8rx7forum.com/showthread...-Base-se-build
http://www.v8rx7forum.com/showthread...ht=#post548208
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
