307
Old Apr 15, 2010 | 08:39 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
307
would it be possible to swap a 307 into a camaro from a 72 nova? and if so could i put the stock tbi unit on it?
Old Apr 15, 2010 | 08:45 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: 307
it will fit and it will run with tbi.
i take it your getting the 307 very cheap or already have it.
Old Apr 15, 2010 | 09:55 PM
algershick's Avatar
Re: 307
A small block is a small block is a small block, the conversion would be no different from any other SBC transplant!
Old Apr 15, 2010 | 10:31 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
Re: 307
i knew it would bolt up and everything. i guess what i should have asked is if it would run with a stock pcm? i didnt know because its about the same size but i have no clue about the internals. and i would be picking it up for very cheap and it supposedly only has 40000 on a rebuild. and the guy has all the paperwork and recipts from the builder.
Old Apr 15, 2010 | 11:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 307
guys, this OP just posted in general about tweaking his LO3.
Unless there's something wrong with the LO3, leave it in the car, and let this 307 go. It's not worth the hassle.
Old Apr 15, 2010 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 307
307 is a boat anchor. Inexpensive or free isn't a good deal when what you're getting isn't even worth scrap metal value.
Old Apr 16, 2010 | 12:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What really made the 307 boat anchors were the heads, cam, and 2 bbl carb. It actually has a more favorable bore/stroke than the 305.
BUT...
As stated above, unless there is something mortally wrong with your LO3, and the 307 is ready to run as-is, it really wouldn't be worth it. The 307 has 2-piece rear main seal (vs. 1-piece for the LO3), dipstick on the driver side (vs. passenger side for the LO3), flat tappet lifters (vs. roller for the LO3), and the LO3 heads, as lame as they are, would be better than any factory 307 head (and using them would aid mounting the TBI intake manifold).
If you think you'll have more power just by installing the 307 in place of the 305, ain't gonna happen.
Old Apr 16, 2010 | 10:18 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 307
What he said. All true. But...
In the spirit of fairness, here's a link to the only 307 build ever done, so far as I can tell:
http://www.superchevy.com/technical/...ive/index.html
They spent over $2000 just to end up with 315 HP.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Thunderboy
Sep 19, 2003 08:08 PM
82firebird
Apr 23, 2001 03:12 PM
virtual
Mar 25, 2001 06:07 PM
