pulling 4th gen engine
Old Apr 17, 2010 | 09:26 PM
89R-roc's Avatar
Car: 89 Camaro Rs
Engine: 305(lo3) with some mods
Transmission: 700r4 with shift kit
Axle/Gears: 2.73 open
What would be the easiest way to pull an lt1 from a 4th gen to put in my 86? the car was t boned so i though about cutting up the front end, but i also thought about unbolting the k member and picking the car up off the engine. any other ideas?
Old Apr 17, 2010 | 09:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: pulling 4th gen engine
dropping the k-member is the easiest if you have the means.
Old Apr 17, 2010 | 09:41 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
thats how i did it to pull my LS1 from a 4th gen...also how i put it in my car
Old Apr 17, 2010 | 09:48 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Unbolt the k-member, take the ones out of the bottom first, then unbolt the struts. The only way to get a motor out of a 4th gen.
Old Apr 17, 2010 | 09:49 PM
89R-roc's Avatar
Car: 89 Camaro Rs
well i got a tractor with a bucket, tools engine hoist and lots of friends and beer so it will get out one way or the other. thanks
Old Apr 17, 2010 | 09:54 PM
Zepher's Avatar
It can go in and out from the top.
Old Apr 17, 2010 | 10:01 PM
89R-roc's Avatar
Car: 89 Camaro Rs
also wouldn't i have to unbolt the transmission cross member and undo the torque arm?
Old Apr 17, 2010 | 10:23 PM
Zepher's Avatar
just remove the driveshaft, torque arm mount, and crossmember
remember to unplug any wires, cables, hoses, etc that go to the tranny.
Old Apr 18, 2010 | 09:13 AM
Klortho's Avatar
Car: 1987 GTA
Not with one that was in a front end collision.....
if you want to take it out the most complete without having to disassemble most of the motor, take it out from the bottom, I've pulled a bunch from 4th gens and that's the quickest.
Old Apr 18, 2010 | 09:30 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
agreed
Old Apr 18, 2010 | 09:59 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
ive seen several 4th gen motors pulled and installed through the top.As long as the damage isnt too bad in the front you can do it that way too.
Old Apr 18, 2010 | 03:05 PM
Zepher's Avatar
I know the k-member way is the easiest and fastest. you did notice I was the first to post in this thread.
The way you phrased your post can be misleading,
someone reads that and may think it can't come out of the top.
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
