New 383 pulling oil from PCV to intake
Old Apr 22, 2010 | 08:44 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I have a new 383 with like 3 miles on it. I had it engine dynoed at the engine builder and he told me he had an issue with the PCV pulling oil into the intake I smokes his dyno room out. He disconnected them and the issue cleared...He told me it was because I had no baffles in my Brodix valve covers. So I ordered new gromets from Summit that were inclosed at the bottom like a cup, cupping the PCV and a small hole to let them breath. I Installed the engine had it flatbedded to the chassie dyno tune shop and the car was smoking really bad again. Pull the PVC to fine the gromets have filled with oil and its being pulled into the lower intake and TB. Disconnect them and the smoke issue clears from the exaust. I then cut the bottom from the gromets so they just had long sleaves over the PCV. So it still pulled oil, just ended up running the rubber PVC hose to a bottle to collect oil. Also seem to have oil pushing up the valve cover bolts and leaking there too. Any idea what would cause this?? How do I correct this?? I'm prob going to order sheet metal baffles to block the oil splash to the PCV area from summit and see if I connect the PCV in the stock configuration if it works any better. I almost brought a crank case evac setup from Summit...1 tech told me to get it but the next 3 said its only for cars with no mufflers....Any input would be great, this is making me crazy!...mods in sig
Old Apr 22, 2010 | 08:56 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: New 383 pulling oil from PCV to intake
sounds to me like the rings are not sealing and it is causing to much crankcase pressure in the engine.
Old Apr 23, 2010 | 07:13 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I think you should try some valve covers with the baffle built in, I don't think those grommets will work as well as actual baffles.
If that fails you should perform a leak down test to ensure ring sealing, I once had a 305 that had so much blow by it pushed oil out of the dipstick tube<- alot of oil
Old Apr 23, 2010 | 07:19 PM
Car: 89 Formula 350
I just ordered this from Summit...Hoping they are my fix
http://www.summitracing.com/parts/MOR-68790/
Old Apr 23, 2010 | 07:45 PM
one92rs's Avatar
Car: SOLD!!!!!
i am using only the grommets and i dont have that problem.
Old Apr 23, 2010 | 07:52 PM
Car: 89 Formula 350
I'm pushing 50lbs of oil pressure at an ideal...so with the big roller cam the oil is splashing alot....when I had a stock L98 I didnt need baffles eighter but I sure do now
Old Apr 25, 2010 | 03:48 AM
MrMaro92's Avatar
hey im sure u have checked this but just an idea in my 88 maro i had a similiar problem the guy who built my motor put in to much of a to heavy weight of oil and it did what ur saying urs is have u checked this? just thought id throw that out there
Old Apr 28, 2010 | 10:04 PM
Car: 89 Formula 350
installed baffles, no more problem
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 12:07 PM
