not start
Old May 1, 2010 | 01:24 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
not start
Swap in a tpi in place of my tbi. got a 7730 ecm ADPH code and modify the chip for no vats. install everything and rewired. I get power to the injectors but the ecm will not trigger them. I crank it and the ecm will power the fuel pump. what is next to check?
Old May 1, 2010 | 07:44 PM
Re: not start
Got it running. the tps sensor was pinned differently on my tbi then the tpi sensor. found a 4.2 volts on signal back to ecm and believe this was cuz the clear flood mode
Old May 1, 2010 | 07:46 PM
Re: not start
anyone got a pin out of all the pins in the aldl connector? I can't connected with my scan tool yet. I know about pin m and e and have tried that. any of the connector pins to be 12 v to supply a scanner power?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
