rebuilding 350
Old May 12, 2010 | 01:02 PM
dare19's Avatar
rebuilding 350
i am about to start working on an 86 trans am with a 350 already swaped in. The engine needs to be pulled and rebuilt. any advice, tips, or products that can be used to build it up with wld be much appreciated. also I am working off a college student budget. I have the money to spend where needed but wld like to save where i can. Thanks
Old May 12, 2010 | 01:17 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: rebuilding 350
carbureted or injected?
Either way, the place to put the money is the heads. The best idea is usually the Vortec heads, plan on those.
Old May 12, 2010 | 01:25 PM
dare19's Avatar
Re: rebuilding 350
thanx. and its carburated.
Old May 12, 2010 | 09:03 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: rebuilding 350
I agree with Atilla, Ive got iron vortec heads on my stroker and they just kick ***.
Old May 12, 2010 | 10:07 PM
dare19's Avatar
Re: rebuilding 350
thanx. i have a good idea of sum things we're gonna do but just needed an idea of types and brands of good mods
Old May 12, 2010 | 11:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: rebuilding 350
First is a 3" cat-back exhaust. So many good choices, pick whatever you like, then ask us just to be sure, because a few have restrictive mufflers. There's a sub-forum here in TGO just for exhaust, start there.
Second is headers with matching Y-pipe. The Hedmans are popular for their low price, but the matching Y-pipe is too restrictive. Edelbrocks are California legal, but also suck. the best choices are either Hooker's 2055, or the Mac Performance 8692, which is virtually identical in results to the hooker, but stainless steel so it'll last forever.
Mac does a matching cat-back that flows excellent.
From there, we need to know your trans and your axle ratio to help suggest a camshaft. If you're willing to change the axle ratio, you can have a more serious cam, and more power.
Intake manifold depends on your hood and your cam.
cam will also determine flat top or dished pistons.
Old May 13, 2010 | 12:47 PM
dare19's Avatar
Re: rebuilding 350
a friend and i are now in the proccess of removing the engine and once we hae everything squared away with that i will get all the info put up here for a better idea of wat i need
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
