350 or 305 ?
Old May 22, 2010 | 08:33 PM
timonator's Avatar
350 or 305 ?
Im about to purchace a 91 Z28. The guy selling the car says it's a 350 but I don't think he's very car savvy. where on the engine do I look to Id it, and what should I see?
Old May 22, 2010 | 09:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The engine block casting number is the only sure way, and it isn't easy to see - behind the driver side head on the bell housing casting.
Sometimes the last three digits of the casting number is cast into the side of the block, viewable from underneath. Get it up into the air (safely), have a light available, and look for it.
The 8th character of the VIN will tell what engine the factory put in it. "F" = 305, "8" = 350. But, even if it had a 350 in it from the factory, it may have been replaced with a 305 in the last 19 years.
Old May 24, 2010 | 05:50 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 or 305 ?
Also, if it was built with a 350, it should have dual cats under it. If not, then the car is worth a few $$ less. Not all 350s actually came with rear discs in '91, in fact, most didn't. But the '91 350s should have a 3.23:1 posi. If it's a 5-speed, it wasn't a 350. GM did NOT offer them that way.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
