305 tbi to 350 tpi or carb
Old May 23, 2010 | 03:41 PM
TUCK1975's Avatar
Car: 1992 firebird vert
Engine: 355 soon to be a 406
Transmission: 700r4 goin t5 then t56
Axle/Gears: 373 or 410
ok getting ready to start my motor build i have a 305tbi in my firebird im going to build a 350 for it and have a tpi setup with heads and everything but dont know if i want to fool with all the computer crap just wondering witch would be more maintanance free the carb or the tpi and which will give better performance any sugestions
Old May 23, 2010 | 04:42 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 305 tbi to 350 tpi or carb
A stock TPI will barely feed a stock 350. If you have even a very mildly built 350, the TPI will fall flat on its face. Unless you plan on going to a Holley Stealth Ram or Accell SuperRam setup or something of the like, your in for a lot of headaches and dissapoinments. If you know how to tune a carb, it will be way easier, but not even remotely legal. If you have emissions testing and inspections, youll need all the AIR stuff and fuel injection.
Old May 23, 2010 | 05:55 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
350tpi with HSR swap. thats my set up and its the best way to go. you get more power thru hsr then carb
Old May 23, 2010 | 06:32 PM
travis401's Avatar
Car: 91 Camaro RS
True, but HSR isnt cheap. Used carbs can be had a lot cheaper, and a rebuilt kit doesnt cost much either.
Old May 23, 2010 | 08:07 PM
TUCK1975's Avatar
ok sorry bout this but im new on here but what is hsr
Old May 23, 2010 | 08:29 PM
travis401's Avatar
Car: 91 Camaro RS
Holley Stealth Ram
Old May 24, 2010 | 12:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
But the HSR will be new. Buying used is usually buying someone else's problems. It would cost more to convert over to carb with new, reliable parts than it would be to install an HSR.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
