My Procharged 383 Swap
Old Jun 8, 2010 | 07:15 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
Hey everyone, I thought I would start my own 383 swap thread. I should get the rest of the parts ordered in the next month and start the project..
It is a 383, 9:1 Comp, Forged Eagle H beam rods, Forged Eagle crank, and Forged pistons (not sure on what pistons are in it).. AFR 195 heads, 1.52 and 1.6 roller rockers, ported HSR, Holley 58mm throttle body, Centerforce SFI steel flywheel, Centerforce Dual friction clutch, and MSD Pro Billet Distributor. That is what I have so far..... and a P600 Procharger with 9 lbs of boost hopefully.. more boost would be awesome.
This motor made 530 HP and 575 TQ in a Firebird. Ran 11.4 at Bandimere (5800 Ft above sea level)..... We will see what she does in my Maro. And also what she breaks.. ha... i hear more $$$$9in$$$T56$$$$haha
Here are some random pics of stuff so far.
Old Jun 8, 2010 | 08:36 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: My Procharged 383 Swap
Thats a sweeeet motor, keep us updated with your progress!
Old Jun 8, 2010 | 08:50 PM
Thanks! and FOR SURE!!! I need to order the aeromotive fpr, injectors, fittings, hose, motor mounts, fuel rails, coil, and alot of other small stuff. Hopefully I can get everything by the end of the month..
Just started my new job out of high school, so ya. tight budget... haha
Old Jun 8, 2010 | 08:53 PM
Ha, I hear ya. Been out of high school probably right at a year now, I need a job to finish my camaro, lol.
Old Jun 8, 2010 | 08:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
wheres the procharger?
Old Jun 8, 2010 | 09:00 PM
ya, im about to throw this motor in, and i have the t5 and stock 10 bolt with 3.73s and lsd. i already broke 4 pinion teeth off the pinion gear in january with the current 400 hp and 458 tq.. so im nervous once i get the motor in.. i need to save up after and get a 9 in and a t56.. haha..
Here are some pics of when i broke the rear..
Old Jun 8, 2010 | 09:05 PM
O and it'll have a Procharger P600b, with the smallest pulley they make for it. so im hopin 9+ lbs of boost. (my car hit 10 lbs of boost one night, with my current 350 and pulley... but i have been told the 383 will not hit 9 lbs on a 383 with a p600... we will see)
Old Jun 8, 2010 | 10:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im running around on an F1a with my 383 on a stock ten bolt. was 7psi, now its 14psi with the new 4.5" pulley.
Old Jun 8, 2010 | 11:43 PM
What kind of hp are you seeing with that F1A?
Old Jun 8, 2010 | 11:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no idea, havnt dynoed, if i had to make an honest guess, id say somewhere between 600-800
Old Jun 9, 2010 | 12:02 AM
thats sweeeet.. have you taken it to the track?
Old Jun 9, 2010 | 12:03 AM
O and do you have any pics of your car? i want to see your setup. sounds sick
Old Jun 9, 2010 | 12:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
not yet, was getting it running good on 7psi, and trans went, so out went the 700r4 and in went the th400, and while i was doing a trans swapped, i put on a smaller pulley for 14psi estimated.. and then decided to do a few other things. you know how it goes.. new brakes, and I sold my efi, and im still saving for the new efi system to replace it. so for now its sitting. at least another month.
Old Jun 9, 2010 | 12:13 AM
right on that is sickkkk!! and that stinks its sitting. but once i start pullin my motor it will sit for a bit cause im workin all the time now...
So i was curious, the way your vbelt system is setup, was that part of the F1A kit?
Old Jun 9, 2010 | 12:37 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Id put in a new rear and trans before even trying to drop that engine in. Youre gonna have to build up a t-56 to survive behind that much torque too, a straight stock dropout wont last long (unless you get one from a viper).
Old Jun 9, 2010 | 08:26 AM
ya i know. we will see how long it and the rear will last.
Old Jun 9, 2010 | 12:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Only thing that came with the F1A was the crank, alternator, waterpump, and blower pulleys.
the power steering relocation bracket was seperate, but purchased from procharger as well, which requires a newer gm type 2 pump with remote resevoir, and the alternator location is totally custom. I had to get the depth right, and I mounted it with some long *** bolts and tube sleeves, and for adjusting tension, I used a double spherical rod end purchased from march pulley company and that mounts from the ear of the alternator to a stud on the water pump.
Old Jun 9, 2010 | 02:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd say you should be nervous.
Auto trans and street-only so far, right? Apples & oranges.
Old Jun 9, 2010 | 02:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
and its staying street tires till I can afford something better
Old Jun 9, 2010 | 02:58 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
The same pulley on a 383 vs 350 will probably make less boost pressure. But will actually make more power because the 383 will move more air so it's actually making it in to the engine instead of stacking up in the intake. So I wouldn't worry about the actual PSI being lower.
Looks like a mean engine! You def. need to step up to a 12bolt/9" and you will be on borrowed time with a stock T56.
Old Jun 9, 2010 | 11:24 PM
Thanks, and ya 9in and t56 with gforce internals is next once the motor goes in..
Old Jun 9, 2010 | 11:26 PM
like i said, we will see how she does... five7kid, are you going to Bandimere sunday??
Old Jun 10, 2010 | 02:04 PM
Sweet!
Old Jun 10, 2010 | 02:33 PM
five7kid's Avatar
With the '57, yes. Weather isn't looking too promising.
Old Jun 10, 2010 | 10:49 PM
ya todays weather wasnt cool... I was locking cars at a dealership in the rain and lightning.. Haha. Ill pry go up sun.... and pry run my car at this up coming test and tune wednesday
Old Jun 13, 2010 | 11:33 PM
jpellerito's Avatar
yeah, I have had problems with my tach. What can you do to fix it?
Old Jul 9, 2010 | 05:27 PM
Hey everyone i thought id post an update... I ordered a bunch of parts last night, and plan on starting to pull my stock 350 out the 25th ish...
Cant wait.. post more pics soon..
Old Jul 14, 2010 | 11:21 PM
hey everyone, i got excited and decided to pull the motor after work today.. started at 4:30, and went up stairs at 9:30.. not bad for just me... here are a few pics..
zoom 305 clutch that handled 400 hp and 458 tq hahaha
Size:  85.2 KBName:  0714102103-00.jpg
Old Jul 20, 2010 | 07:48 PM
update, i got the a arms, k member and steering box out today... still alot of stuff to do.. here are some pics.. let me know what you all think!! and yes i know its getting crazy!! everything torn apart..
bottom pic, motor mounts macked up... i think i need different bolts haha ( the two long bolts, the three that go into the block are only threaded in two turns so they are ok..)
Size:  101.9 KBName:  0720101703-00.jpg
Old Jul 27, 2010 | 06:41 PM
update, went to ace, got some fuel rail bolts and motor mount bolts.. got the intake bolted on, and rtv'd.. put the blower bracket on and temp mounted the blower on.. here are a few pics.
Old Jul 27, 2010 | 07:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
looking good so far!
Old Jul 27, 2010 | 07:46 PM
Thanks man, just need fuel lines, injectors and the tubular k member and pinto rack.. elimintate all the stock steering. im excited.
Old Aug 3, 2010 | 01:19 AM
hey everyone, i tried to gloss black ratle can the engine bay... it didnt turn out to good, so i am now sand blasting it and having someone paint it that knows what they are doing.
Should i go gloss black or satin black for the engine bay??
Old Aug 3, 2010 | 11:10 PM
Anyone? any input??
new pic. motor just about ready to go in. just need k member.
Old Aug 3, 2010 | 11:16 PM
Very nice!
I like the old (Vette?) valve covers.
And I like both Gloss/Satin black in engine bays. Just depends on the look your going for. I think that satin will make the motor stand out more, whereas gloss will "blend" it in a little better.
Old Aug 3, 2010 | 11:29 PM
thanks for the reply man, and ya they are the older vette valve covers that were painted. i think i might flat black the engine bay. it will be close to satin.. i tried gloss black but it didnt turn out good..
Old Aug 8, 2010 | 04:31 PM
hey guys, i decided to give painting it myself one more try. let me know what u think.
Old Aug 8, 2010 | 05:35 PM
Looks pretty good, I used flat black in my old firebird, and I liked it. Did you rattle-can it?
Old Aug 8, 2010 | 06:09 PM
yup few cans of flat black. it looks better than when i tried gloss blacking it. gloss out of rattle cans is hard. i think ill leave it the way it looks now..
Do you have any pics of your flat black on ur firebird?
Old Aug 10, 2010 | 07:36 PM
update, interior wiring out.
No wiring, looks GOOD!!!!!.. for now...
going through the wiring in my room!! haha
Old Aug 10, 2010 | 07:50 PM
Why'd you pull the interior harness out?
Heres a pic I found in my photobucket of my old firebird with the flat black bay:
(It was a project that never got finished)
Old Aug 10, 2010 | 11:04 PM
  #42
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Nice, I was going to mention satin black would look great. That motor is looking good.
Old Aug 10, 2010 | 11:13 PM
  #43
that looks good! i pulled the interior cause i wanna go through it and get rid of useless wires, like cruise control, and also, when i did my 350 swap i hacked up a lot of wires....
Old Aug 17, 2010 | 10:11 PM
  #44
Hey everyone, here is a recent pic.. getting my custom blower bracket made in the next week or two.
Old Aug 22, 2010 | 10:31 PM
  #45
new pic for u guys
Old Aug 23, 2010 | 12:26 AM
  #46
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Nice, how tall are those AFR valve covers? I was looking at changing my set for a set of those but my turbos sit right on the current covers, so they cant be too tall
Looks good tho
Old Aug 23, 2010 | 12:55 AM
  #47
Looks good tho
they are about 3-3.5 inches tall. i have to get a bracket made for my blower, the valve covers were hitting the blower a lil..
and i need to go find a pic of ur motor, i cant remember what ur covers look like, and where the turbos mount..
and thanks man, i like the new covers..
today i had to temporarly put the k member, and motor in, cause i went in my garage today, had the motor sitting on a tire, and it was about to tip over!.. started collapsing the tire.. scary moment
Old Sep 13, 2010 | 11:55 PM
  #48
Update everyone, it has been alot of caos in the last few weeks.... I have a 1994 S10 Blazer that just took a **** on me.. pretty sure it has a spun main bearing and the tranny is all jacked.. so i decided to get the Maro done then deal with that...
But here is what i have done now..
Finally got my Custom Machined blower bracket back ($140+Material)
Got my coil mounted, fuel rails on, spark plug wires and wire looms mounted, fuel injectors on, etc.......
Cowl on..
Still trying to trim that damn hood to clear everything, and need to pull the bumper up.. GRRRRRRR... but it looks sick
Got the fuel system finished up today, tested it, and wiring is all done... just need my k member, a arms, rack and pinion and can start it!!!!
its hard not to just start it now, but the motor is just sitting on the stock k member haha.. i better wait.. haha
Let me know what u guys think!!
Old Sep 20, 2010 | 11:26 PM
  #49
got the motor running
http://www.youtube.com/watch?v=wyVzAc9yWqE
Old Sep 26, 2010 | 08:04 PM
  #50
Camaro is done here are some pics.
K Member and Rack
Installed
Out of the garage
