Locating the power steering
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Anyone have a good idea how to locate the power steering in an 87 iroc camaro on a Gen 1 small block chevy swap. I am doing an engine swap but can not figure out how to get the power steering on the new engine. The old bracket off the 305 tpi attaches on the outside of the exhaust manifold. I put hooker headers on and so I can not attach to them. It would seem that anyone who has put headers on with the existing TPI set up would have run into this problem as well. Any ideas how to get that bracket to attach that has the belt tensionier slide on it? Or is their an after market bracket to attach the power steering?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Locating the power steering
I never cared if my engines look ghetto, so I just use a longer bolt and a stack of washers. It works just fine.
ever tried a pipe that fits around the bolt to clean it up? Just thought of that. I think I need to use similar spacing techniques to get it to screw in through the other holes as well. Done that before any tips?
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i made my own bracket that utilizes the two bolt holes on the front of the drivers side head
Transmission: 4L80E/4L80E
Which Hooker headers did you put on? The 2055HKR's come with the spacer so you can use the original exhaust manifold bolt in that one place.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'd bet it was the 2460s. The initial price is lower, but the consequence is nearly always that the local-made Y-pipe doesn't flow as well as the Y that Hooker only includes with the 2055s, instead of also offering separately. That's why I prefer MAC Performance.
I had hedman shorties on this, no issues. Simply uses a small spacer as a standoff and a long bolt.
The rest is all original 87 setup, the typical flat belt/v belt combo.
See attachment
See attachment
Got it done. I used the stud bolt off the old 305. Then I had a piece of pipe that fit around the bolt cut to the right length all in place and ready for the next challange
. Thanks for the suggestions the spacer worked.
. Thanks for the suggestions the spacer worked. Thread Starter
As far as which headers, yeah I must have got the wrong ones.
That's pretty typical for me
Either that or it was in the bag and I did not see it.
Either that or it was in the bag and I did not see it. Joined: Mar 2000
If your headers didn't come with a Y-pipe (and seeing your picture, I doubt they did), they aren't the 2055HKR's. I don't know one way or the other if the 2460HKR's come with the spacer, but I'd guess they don't.
Doing what you did is the correct way to resolve the issue. The tube/spacer should be the same length as the stock exhaust manifold is thick where the bolt goes through it.
It is I measured before I cut for once. I am slow but figuring it out. Amazing that somethings are actually working the first time now because of the imense pain I previously caused myself. They are hard lessons to forget
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
