2.8 v6 to 383 stroker
Old Jun 18, 2010 | 02:54 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
idk how hard it would be to swap a 2.8 to a 383 stroker motor.
would it be easyer to swap a 4.3 than a 383
and will the insurance go up or down if i put a v8 into a v6 car
Old Jun 21, 2010 | 01:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Personally, I'd say it would be easier to swap in a V8 than a 4.3 V6, since the V8 is at least a configuration the factory used in 3rd gens.
Old Jun 21, 2010 | 07:12 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 2.8 v6 to 383 stroker
Not too hard, motor mounts have to get relocated and you have to change the fuel pump and trans (depending on trans may also have to change trans mount, cross member, and I'm drawing a blank on the name of it but the support that runs from the trans tailshaft to the rear axle). And invest in a new rear and front suspension.
I'd go with the V8.
alexdavis001
Jun 21, 2010 09:15 AM
86'Frankenstein
May 22, 2007 05:48 PM
Really-Slow-RS
Apr 20, 2006 07:28 PM
88camaro383
Aug 1, 2003 02:15 PM
camarokev400
Jun 5, 2002 12:27 AM
