Taking out air conditioning for new wiring harness?
Old Jun 20, 2010 | 10:16 AM
jlanham's Avatar
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Hey that air conditioning box on the passenger side of the firewall sure takes up a lot of space. If I take it all out is there a good spot to run wires through to the new ecm? I ask this because the holley wiring harness for the stealth ram is not long enough to reach down the the TPI wiring harness hole and still get over to all the sensors. Particularly the O2 sensor on the driver side header. By it's length it is clearly meant to go through the fire wall not far from the engine. They provide a rubber grummit for this. Is it fairly easy to cover the AC hole and is that a good spot? I would love to have more room on the fire wall as it is getting crowded and I still have some ignition stuff to mount. I wanted it to have a cleaner look.
Old Jun 20, 2010 | 11:28 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Taking out air conditioning for new wiring harness?
You'll be deleting the heat along with the A/C if you remove all that - Alaska seems like a good place to retain heat! (unless this is a strip-only car)
You can do an A/C delete box which is slightly smaller and way better looking, and keep the heat - then you would maybe have the room to cut through the firewall to the side of it or below it to run your harness.
Maybe contact Holley to see if they offer plug-n-play extensions for your short wires, or thye can tell you what kind of wiring and splicing techniques to extend on your own.
Old Jun 20, 2010 | 11:32 AM
jlanham's Avatar
Any threads or leads on how to do the a/c delete box while retaining the heat?
Old Jun 20, 2010 | 11:42 AM
Car: 1992 RS
Engine: Carbed 350
1) Get the A/C delete box about $100 - ebay, classifieds here, thirdgen ranch, etc.
2) remove your A/C box - there is a 2in by 2in diamond looking thing with a connector has 2 small screws holding it in - KEEP THIS and mount it in the hole on the A/C delete box - this is the resistors for your blower motor.
3) most of us had to cut into the power wires for the blower motor and attach spade connectors for the connectors on the A/C delete box
4) A/C delete box uses a smaller cage fan, so if yours didn't come with the cage fan, you'll need a smaller one from autoparts store or JY
Removal - there is one or two studs that go through from the engine bay and have nuts on them inside the pass floorboard - they are on the bottom - the rest of the bolts that hold it on the firewall are on engine bay side.
Can search "a/c delete" in the cooling section - there's alot of threads there on it
Old Jun 20, 2010 | 11:53 AM
jlanham's Avatar
Thanks I appreciate all the help. Thats a very complete answer !
Old Jun 20, 2010 | 12:15 PM
Pocket's Avatar
Car: 91 Trans Am
Drill a small hole under the HVAC box and route the ECM harness through it. Clean and functional while retaining the parts you want to keep like heat
Fiero blower motors are the same dimensions as the non-AC blower motors. May help your search
Old Jun 20, 2010 | 04:34 PM
jlanham's Avatar
excellent. I may be able to do this without eliminating the air conditioning box yet. Looks like the cheapest I can find it is $149 online and that is without any of the blower motors ect. May just live with the box for a while. There is not exactly a junk yard where I live SE Alaska. I will have to post some pictures later today with what I have got done so far as I have had quite a bit of help on multiple threads and some people might think it is cool to see their suggestions finished
Old Jun 21, 2010 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by camaronewbie
Removal - there is one or two studs that go through from the engine bay and have nuts on them inside the pass floorboard - they are on the bottom...
Mine on the bottom were bolts that were in the passenger compartment going through the firewall into the housing. No studs.
Old Jun 21, 2010 | 03:13 PM
Car: 1992 RS
Engine: Carbed 350
That may have been it - I just remember having to undo 1 or 2 from the inside.
Old Jun 21, 2010 | 03:56 PM
Pocket's Avatar
Car: 91 Trans Am
Bottom 3 are from the interior. Non-AC boxes only use two of those
Theres one stud from the engine bay side. You can see it behind the #8 coil pack. Its quite annoying and often strips out requiring vice grips and a box end wrench. It can be replaced with a standard coarse thread bolt, but requires the interior side HVAC box to be removed in order to get the stud out
Old Jun 21, 2010 | 08:40 PM
jlanham's Avatar
I was able to pull one of the fuses on the new wiring harness back up into the original wire harness hole and buy a few inches and make it all work. The downside is if that fuse ever blows I will have to disconnect 2 or three sensors to get to it. I printed out your alls advice and I am going to change out the A/C box later when I don't have a list of dozens of car parts that are more important to buy!
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
jackhammer
Aug 15, 2015 10:04 PM
