stroker swap update pictures
Old Jun 20, 2010 | 10:45 PM
jlanham's Avatar
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Thanks to all of you who have helped with so many suggestions. I am moving along
The first picture is the wiring harness for the fan that was suggested to me from this site. I was able to get this spliced into the fan harness and the temp sensor plugged in. It's already to go.
You can look at the power steering post on the my other thread to see the spacing suggestion I took from the site to get the power steering mounted.
The second picture is the coil and the map mounting locations that you can see, also suggestions off the site.
So again thanks for all the help and I have more questions coming
Attached Thumbnails stroker swap update pictures-img_3624.jpg   stroker swap update pictures-img_3625.jpg   stroker swap update pictures-img_3644.jpg
Old Jun 20, 2010 | 10:52 PM
jlanham's Avatar
Re: stroker swap update pictures
Question relating to the first picture. This fiting hanging down comes off of the original (non tpi) wire harness not far from all the airconditioning attachments. Is this a ground I need to attach to the back of the block? Is it neccesary if I am not using A/C? Would it have attached somewhere else and not be hanging there if I would have pulled the wire around if I was using A/C?
Question relating to the second picture. This attached to the transmission. What is it? Spedo?
Attached Thumbnails stroker swap update pictures-img_3627.jpg   stroker swap update pictures-img_3628.jpg
Old Jun 20, 2010 | 11:04 PM
jlanham's Avatar
First Picture Question: This is the back of the HSR. The top fitting is where I hook up the MAP vacuum hose. The lower fitting that looks the same the book says to attach a vacuum hose to the fuel pressure regulator. Wheres that?
The second picture shows a hose with a fitting that comes off the factory (non tpi, that one is completely off) wiring harness. That went I believe to the fitting on the third picture on the original tpi motor. The top of the picture (the old motor one 3rd picture) is that the fuel pressure regulator. Do I need to buy one for my new motor, rob from the old one. Are all these pictures related or are these two separate things I need to take care off. I am sure someone knows how to identify all this and what to do.
Attached Thumbnails stroker swap update pictures-img_3641.jpg   stroker swap update pictures-img_3642.jpg   stroker swap update pictures-img_3643.jpg
Old Jun 21, 2010 | 02:07 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
1. Yes that is a ground wire.
2. Yes that is the speedo cable.
Old Jun 21, 2010 | 02:11 AM
Black disc at top is fuel pressure regulator, grey disc at bottom is EGR.
Old Jun 21, 2010 | 08:49 PM
jlanham's Avatar
I don't think I need the EGR. IS that what the fitting from the wiring harness that I have a picture of went to?
Also can I rob the fuel pressure regulator or is it best to buy a new one that I can adjust for the bigger motor/injectors?
Old Jun 23, 2010 | 01:48 AM
jlanham's Avatar
found the regulator. Done with that.
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
bryan623
Aug 10, 2015 11:33 AM
