New Heads!!!
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
New Heads!!!
I just bought a new set of EQ Vortec heads from eBay and I got a them for CHEAP, I got both heads brand new for $260. This is the best deal I found for a set of budget heads.
They are already machined for srew n rocker studs. The Guide od is .530"/.531" for standard PC type seal. The heads still have the big guide bosses. They have a thicker deck surface to. The valves are 1.94/1.5.
They heave a 3 angle valve job. And the best part about these is that there drilled for 69-86 intake pattern so i don't have to buy a new intake.
This is the first set of heads I ever bought and they look like really nice castings to me. There going on my 350 in a couple months after i get the rest of the valve train.
I plan on buying a Lunati 60104 cam&lifter set for the engine.
I got 4.10 gear with th350 rebuilt with a b&m stage 2 shift kit and a 3000 stall go with the combo. The intake is a eddy torquer 2 with a eddy 600cfm performer carb.
Plan on changing to a Holley 750 dp.
Do you guys think this is a good combination to get my camaro moving pretty fast.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: New Heads!!!
+1. Terrible manifold. go performer rpm at the least.
and just because they are drilled for both bolt styles doesnt mean they should be run. (Pretty sure the vortecs are raised runner designs) Someone else can add to that if they want.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: New Heads!!!
Yea, I hope the intake thing come together for you.. as i have never heard good things about drilling the heads for the different intake's.. I heard you can be chasing leaks, i hope this is not the case tho..for you
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Re: New Heads!!!
These heads come with only the standard intake bolt pattern. They are NOT Drilled for Both Intake Patterns. The heads came New out of the EQ box like this, I did not drill them or have a shop do it so i'm sure intake sealing will be fine. I'll let you know for sure though when I put the engine back together.
As for the torquer 2 intake it is all I can afford at the moment got from a friend for cheap. I plan on upgrading to a weiand team g some day
Transmission: 4L80E/4L80E
A Performer RPM or Weiand Stealth would be a better match for that cam. Single plane intakes are for dedicated race cars.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New Heads!!!
Who said the heads are crap? They're decent heads. I was bashing the Torker 2 intake. It really is junk.
Car: '88 Camaro (Gone...)
Re: New Heads!!!
I was confused for a moment too, seeing as RHS markets them as the Torker cylinder heads LOL
http://www.summitracing.com/parts/RHS-12407/
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New Heads!!!
The big valve RHS Vortecs are marketed as Pro Torker heads. At least RHS has some right to use a name referencing torque. Their big valve Vortecs do out-flow all others, by far, and they do have the best combustion chambers as well, again by a measurable margin.
Would I pay the extra $280 for them? Yes.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: New Heads!!!
Whats the best head for a stock 1992 l98 350.. RHS the #12407 with there 1.9 1.5 valves or the 12410 2.02 1.6 ? ? Thanks,
Re: New Heads!!!
I know this post is a year old but the advertised RHS Pro-Torker Vortec flow numbers are generous at best. Go to Stan Weiss site & check out the numbers others have gotten with these heads, they're not that close. Not saying they aren't good heads, just don't take their numbers as gospel truth.
The EQ Vortecs are getting high marks from those who have bought them for how well machined & smooth the castings are, & the flow numbers are pretty consistent
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Re: New Heads!!!
There going on my 355 short block with a comp 292h cam an victor jr intake.....soon
Guest
Posts: n/a
Re: New Heads!!!
The sealing issue comes from the Vortec intake ports being taller than '55-'95 intake ports. You need to buy whatever intake gaskets Edelbrock recommends for that manifold, then compare them against the heads.
Don't be surprised if you can see ports above the tops of the gaskets.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
