wondering if it would be worth it to rebuild my 305
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so i'm going to be taking an engine class (removal, disassemble, clean, reassemble, install). I have the option of either building a dummy engine or bringing in my own and was considering rebuilding my old 305 out of my '84 Z28 (not H.O.)
I really don't care about making all that much HP but i would like to do a couple of things to make it run smoother and increase my MPG (it's at 8 right now lol) I was thinking taking it all apart, cleaning it up, and maybe putting a new intake on it.
i have been going through the threads and most people seem to rebuild for big hp numbers. I'll continue to go through the threads but does anyone have any advice on parts to look at or maybe stay away from and how inexpensive do you guys think i can do a simple rebuild for?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
re: wondering if it would be worth it to rebuild my 305
Go spend your first $150 on getting a 350. I know of at least 3 ways to get 25 mpg (hwy) from a 350, because I've done it all 3 ways. From there, your expenses will be slightly less than to do the 305.
You'll love the extra torque, too!
Transmission: 4L80E/4L80E
Dollars to donuts taking it all apart, cleaning it up, and putting a new intake on it wouldn't change that.
Car: 1984 Z28
Engine: none
Transmission: none
Just an idea, I got my 350 at the local pull-a-part for $45 (complete bottom end), when they're that plentifull and cheap why bother with the 305?
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Well, if you think about it...
You are committed to doing a rebuild of SOMETHING
- If you look at the prices of engine parts, you'll see that up to 85, they are slightly lower for a 350
- If you look at the prices of parts for post-85 engines, you will see that the gap widens further
- The 350 will be more powerful, and can still be fuel efficient.
- Machine work will cost the same, assuming the same work is done on both engines.
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
I agree with Atilla as well. If you dont race your car that often, then just rebuild the 305 with a mild cam like an XE256 and just put some exhaust on it. It should run somewhere in the 14's and get good gas mileage.
I remain to be convinced the 305 would benefit from a rebuild.
Engine: 305 V8
Re: wondering if it would be worth it to rebuild my 305
so i think i'm probably going to pick up a 350 from a pull-a-part down here. anyone have any advice on what to look for or which vehicle to pull one from? what all should i leave on and is there anything else i need to take with it?
Engine: 5 Liter 305
Axle/Gears: 3.45
Anything that is from 1987 up is a good rule of thumb, because they are roller cam ready if not already. But I would look up the vehicle in question before you buy and check the vin. It will tell you the size, and then you can look up the vehicle and see what HP it came with if you wanted. I would get a vortec v8, 255hp, stock and put in a cam and do a little head work. That should net you 275-325hp depending on your intake and exhaust. Maybe more.
10243880 is the number of the block to look for.
Here is a page with all sbc block casting numbers
http://www.rapidomarine.com/default....sting_id_.aspx
Don't forget "San Diego, CA", meaning smog inspection and test.
Engine: 305 V8
Re: 5
yeah, i plan on talking to the guy who runs the auto course for advice and everything. I've already talked with him a bit and e said i could bring my car down and they'll throw it on their smog machine to check it out. They have a referee there and if i remember correctly aren't they the people who give the "ok" for making sure swaps are smog legal and everything is hooked up correctly?
Re: 5
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: 5
You say you are going to be smog legal. You'd best get a game plan of what you are going to do and what you are going to lie about. It looks like you plan to stay carbed. You could avoid the referee by disguising your new motor as the original 305. If you cop to it being a transplanted 350, then you will need to upgrade the computer to match. If you get a later model roller block, then the only carbed 350 would be from a 1987 Caprice(or maybe some model of Cadillac or Pontiac Parisian,idk). Or you could say its a pre 87 but you'd likely need to be using perimeter bolt heads unless you think the ref wouldn't know better. Just saying you should have a game plan before you buy intakes, etc. I've never taken a swap job to a ref, so i don't know how **** they are, but the only way to be absolutely safe is to take everything out of the same car as a package.
http://www.dmv.org/ca-california/smog-check.php
This link has some good info...
Re: 5
...Example: If you have a 85 Z28 with a 305 and swapped in a 350, since the 350 was available in 1987-1992 it would be okay. ...
However, B-bodies had 350 carbs through '87, so you can get it through that way. But, you're still looking at a "motor change".
There is also a smog abatement fee you can pay annually to "exempt" your car if it is 6 years or older according to here
BTW, the only way an inspector could tell an '84 305 from an '84 350 is if he found and read the block casting number.
Engine: 5 Liter 305
Axle/Gears: 3.45
If you have an engine that is newer than your chassis, you have to have all of the equipment the engine had in the vehicle in which it was certified. F-bodies never came with a 350 with a carb, only TPI.
Look again - it says "6 years old or newer".
OP - Go EFI 350 and you will be fine. TPI set ups go complete for like $200 on craiglist. I have an upper plenum and runners if interested.
Engine: 305 V8
lame...i wish i could just put all the 305 stuff on the 350 and it would be alright but whatever. I think i'm just going to do a simple rebuild on the 305 for some general knowledge and fun. Maybe when i move i'll plan a bigger build where i don't have to worry about such things.
Engine: 5 Liter 305
Axle/Gears: 3.45
that's what five7kid and I are alluding to. If you put in a 350 with a mildish cam, and drove it to the smog shop when tags were due, nobody is going to know its not the original motor. paint it black. if it were me, I'd find a 400 before class starts.
Engine: 305 V8
i've decided to go with the 305, so a couple questions.
first, which stock heads (junkyard rat
) would best fit this intake without having to mod the intake to fit it (thanks five7):
http://www.summitracing.com/parts/NAL-10185063/
second, can anyone recommend a cam kit to use? and should i get new rockers/springs? and if i only do one of those which would be recommended?
) would best fit this intake without having to mod the intake to fit it (thanks five7):http://www.summitracing.com/parts/NAL-10185063/
Engine: 5 Liter 305
Axle/Gears: 3.45
Pretty much any cam that has an idle to 5500rpm will work. Match your stuff. If you are carb I would shoot for a 110-112LSA 216-224 duration and .460-.500 lift, depending on springs and heads.
The heads on your 305 now are better than what you'll find at the junkyard (that will work with that manifold).
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That dual plane intake will need a comp XE256 or XE262, dont over cam it, its not worth the dynamic compression loss. If you play your cards right with the heads, it will pull til 5600-6000rpm, and it will sound lopey regardless.
Engine: 5 Liter 305
Axle/Gears: 3.45
Edit...Oops, im getting my threads mixed up, talking to 2 people doing this! lol
Engine: 305 V8
okie dokie, i wasn't sure if the heads on say a '84 HO would be any better. anybody know if there are better stock manifolds/y-pipe? $500 might be a bit much right now for headers.
Engine: 305 V8
http://www.summitracing.com/parts/CCA-12-205-2/
would it be worth it to get the whole kit for ~$300:
http://www.summitracing.com/parts/CCA-K12-205-2/
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The HO heads are NO different from what you have, 416s. The HO manifolds and y-pipe were better, but aren't technically legal, especially in Cali, unless you change EVERYTHING to HO spec. Cam, pistons, gearing, computer, EVERYTHING.
The ZZ4 can be legal for your car, if done per the old GM conversion kit specs. In legal form, using the B2L exhaust manifolds, it made 308 hp and 367 ft-lbs.
But there's no cheap way to make much over 225 or so horses and be Cali-legal, because you started with the wrong car. Yes, that's the right cam. The kit has good lifters, but too much spring pressure, so I'd go with different springs. Also, that timing chain is too cheap, it will stretch an awful lot. Not good.
Engine: 305 V8
On Probation
Engine: several
Transmission: none
Axle/Gears: none
For the springs; http://www.summitracing.com/parts/EDL-5802/ with your stock retainers and rotators. For the timing set; http://www.summitracing.com/parts/CLO-C-3023X/
hectre13
Dec 11, 2023 08:14 AM
