350 or 400
Old Jul 17, 2010 | 05:34 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
350 or 400
i have access to both a 350 and a 400 engine, either would be built before putting it in, which in your oppinions would be better? probably will go carb
Old Jul 17, 2010 | 08:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 or 400
If you can't afford great heads, then the 400 will run out of air nearly 1000 rpm sooner than the 350.
Start by buying the mandatory supporting hardware, such as headers and 3" exhaust. Then decide what the build will cost. Whatever's left over is your budget for heads, and the heads determine the power potential.
Buy the best heads you can, but it's hard to choose heads until you know your cubes.
So, if your budget for heads is $400, then you'll be going with used, freshened Vortecs, so go 350. If your budget for heads is $900, then you can afford some good iron heads, so go with the 400. If your budget for heads is $1500, then you can get some great aluminum heads, so choose the 400.
Old Jul 18, 2010 | 03:00 AM
Chevy8588's Avatar
Re: 350 or 400
well thats the nice part, I already have headers and a 3" exhaust. and a 305 that performs well enough to justify spending some extra time on this build if money is tight, soooo 400 it is!
Old Jul 20, 2010 | 08:57 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: 350 or 400
my oppinon take 350 60 over with some 11.5.1 or 12.5.1 compression if your not using spray or turbo or supercharger this should give you a 410 cubic inches if you use a 400 style crank
If you take 400 30 over its only 406 cubic inches... Dont want to take them much more then this because of the cylinder walls are so thin
I took my 410 and had it in the 9s easy in a full steel body nova
I took my 406 and was high 10s in same set up car with same everything but short block
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
