ho305 heads on 350 questions
Old Jul 19, 2010 | 07:23 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
my heads should be done friday, the 416 heads ported and polished with 194's installed. all cleaned up, now i am installing this on my 91 1piece rear main block. it has like 50k on it. a bare bones cam and lifter kit. http://www.summitracing.com/parts/LUN-10000LK/ new dual roller timing chain. and all new gaskets.
my question is what head gaskets to use? and should i get a set of arp head studs?? this motor just needs to get me buy untill the ls/6speed show up.
Old Jul 19, 2010 | 08:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you measured how far down in the hole the pistons are? Do you know the cc's of the pistons? Have the heads been shaved, or the block decked?
I wouldn't waste money on head bolt studs.
Old Jul 19, 2010 | 09:00 PM
aaronjohn20's Avatar
Car: 1988 Camaro IROC-Z28
Engine: 350ci
Axle/Gears: BorgWarner 2.77
Re: ho305 heads on 350 questions
i've got these same heads on my 355. What pistons do you have? Are they the 4 valve relief pistons? Like stated before, whats the cc's of the combustion chamber? Both of these are gonna be a factor on what head gaskets u are going to need. By the way, how much did it cost you to get your heads ported and polished and the bigger valves put in? I just bought regular arp head bolts, u shouldn't need studs
Old Jul 19, 2010 | 09:08 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
the motor is a stock 91 chevy 350. nothing done to it.
the heads are getting done by my friend at a local machine shop. he just told me they were just cleaned up. but he planed for thirty thousands to be shaved.
well since my buddy is doing it. usually its like 60$ a hour for custom work but since its my buddy he gave me a flat rate for 150$ but i made a deal so money out of my pocket is about 75$ i did the porting my self. mostly just bowl clean up and gasket matching. and the heads are 58cc
Old Jul 19, 2010 | 09:20 PM
Engine: 350ci
i'm not sure on the head gaskets since you plan on having them milled. It's a good thing that they are 4 valve reliefs. Personally i wouldn't mill them at all. Mine are completely stock heads at 58cc and i got to run premium to keep it from spark knocking. I also bought the regular felpro head gaskets that i think are rated for 11:1 CR, but dont quote me on that. So if you mill your heads i would get the MLS head gaskets and you will probably have to end up running real real good gas.
Last edited by aaronjohn20; Jul 19, 2010 at 09:23 PM. Reason: i think i'm probably pushing around 10.5:1 CR
Old Jul 19, 2010 | 10:08 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
how do u like ur set up?? i am just trying something diffrent.
Old Jul 20, 2010 | 12:03 AM
Engine: 350ci
Well to tell you the truth; I've got a 750 edelbrock which is i know way too big. I've got my base timing at 14-16degrees btdc. This is where i'm getting the best throttle response, plus it's all the farther i can turn my distributor. Spark knocks pretty good on the cheap gas. My speedo is off so i have no clue what i've had it up to. It pulls pretty good till you get to about 5000-5500RPM. And i'm having some trouble with my starter not cranking the engine over after it's warmed up. Not quite sure whats up with that yet though. I'm definetley gonna get it to the dragstrip one of these days. But if you ported and polished your heads then they should flow more air, which should pull farther in your RPMS, I'm just guessing here. Oh yeah, i guess i've already said this, but like i said, my heads are stock, COMPLETELY STOCK. Valves are stock, everything. Would love to get em ported and polished and some 2.02/1.6 put in em.
Old Jul 20, 2010 | 09:43 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
iwas told there was no room for 2.02's. and do u have headders.. my starter did the same thing and it was heat soak from the headders. i maid my own heat sheld and now i have no problems. i am going to run my modified 650dp
Old Jul 20, 2010 | 11:27 AM
five7kid's Avatar
Clean up the piston surface and block surface. Bring the piston up to TDC. Measure the distance from the block surface to the uppermost surface of the piston. Subtract that number from 0.040", and get a 350 head gasket with that compressed thickness.
Don't shave the heads unless the gasket surface isn't flat. If they need clean-up, only shave them enough to get them cleaned up. Lack of compression won't be your problem.
Old Jul 20, 2010 | 11:43 AM
Engine: 350ci
no i don't have headers, I'm planning on it though. I wasnt' for sure if 2.02 would fit or not. I havent talked to anyone bout it yet. Yeah i thought my starter problem was either heat soak or too much compression. Just be prepared to run premium fuel.
Old Jul 20, 2010 | 05:04 PM
Engine: 350ci
http://s789.photobucket.com/albums/y...t=100_2928.mp4
Here's a Video link to my current engine running with the 416 heads. Sorry bout the mess and all, working on tight funds. I'll try and get some more pics up
Old Jul 20, 2010 | 05:16 PM
Engine: 350ci
Heres some more, Man do i need to get this thing ready for paint
Attached Thumbnails ho305 heads on 350 questions-100_2925.jpg   ho305 heads on 350 questions-100_2924.jpg   ho305 heads on 350 questions-100_2926.jpg
Old Jul 20, 2010 | 08:50 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
When cranking hard your timing is too advanced if it does it after warmed up due to the compression your running...
Back it off a little bit and see if its easier
Old Jul 21, 2010 | 10:56 AM
Engine: 350ci
yeah i don't really want to back it off, I've got the base timeing at 14-16 degree btdc cause this is where i'm getting the best throttle response. The only down side to running the timeing here is i got to run premium gas and i'm gonna need to get a high torque starter.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
