455 olds into a 89 camaro
Old Jul 18, 2010 | 04:00 PM
goes12s's Avatar
So, i Blew up my sbc 355 and i decided to install a bbc 455 oldsmobile engine, that i had sitting in my garage with a th350. both of them been rebuild and the engine has a cam, bore out, 9.51 compression fully ported stock heads, it has a lots of torque.
Has someone ever done one of this swap? what kind of headers they used, or should i keep the stock manifold, for clearance? Any help? Thanks
Old Jul 18, 2010 | 07:46 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: 455 olds into a 89 camaro
https://www.thirdgen.org/forums/engi...sing-olds.html
https://www.thirdgen.org/forums/engi...wap-455-a.html
Old Jul 18, 2010 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A BBC Olds? When did Chevrolet make an Oldsmobile engine?
Old Jul 18, 2010 | 11:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That's an under statement
Gonna need to tub it to run some 36" wide meats so it hooks
Just make sure n get FAA approval before lift off
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
