Do I need to change oil pan?
Car: 1985 Iroc-Z
First of all I am a bodyman trying to learn about engines, so I am a little dumb about engines. I am doing a 350 swap into my 85 Iroc and I have a 1970 block. Will I need to change oil pans to fit over the K member and if so what should I get?
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If you're thinking of using the '70 oil pan, most likely it will fit.
You won't be able to use your '85 pan on the '70 block, because the dipstick changed sides.
Car: 92 RS
Engine: 5.7 SB
Re: Do I need to change oil pan?
i have a 70-73 block, and the oil pan fits fine, no issues, only thing is dipstick changed from passenger to driver, as Five7Kid stated
Get a vette LT1 pan. good stock pan.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
