L98 Mod Help!
Old Jul 27, 2010 | 02:24 AM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Transmission: 700R4 lookin for shift kit
Axle/Gears: 3.23???
L98 Mod Help!
I was planning to swap out my 305tpi for a 406 carb, I pulled the engine, long story short i want to save that engine for another project. so with that i want to purchase a 350tpi from hawks. correct me if i am wrong but stock 350 tpi makes about 250hp? with that engine, what mods can you guys help me with to get the l98 engine to about 300 to 320 hp??? details would help alot.
thanks in advance
Old Jul 27, 2010 | 12:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 245 net HP rating is about 285-295 gross HP (the way crate engines are "rated").
So, are you talking about getting 300-320 HP out of an L98 instead of getting a crate engine that's rated at that, or taking the 245 net rating up to 300-320?
Old Jul 27, 2010 | 12:49 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Re: L98 Mod Help!
i want to take the 245 to as close to 300 320 as possible
Old Jul 27, 2010 | 12:57 PM
five7kid's Avatar
Then you need about 1 gross HP per cubic inch.
Check Atilla's build sticky for one that matches your combo and goals.
Old Jul 27, 2010 | 01:03 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Re: L98 Mod Help!
i want to keep to the stock tpi, maybe get bigger injectors and heads and cam with choppy idle. do you think that will put me around 300? and i will check that out
Old Jul 27, 2010 | 01:07 PM
five7kid's Avatar
Pretty much backwards. The first stock thing to change is the TPI hardware. Then you can think about cam, injectors, and heads.
Exhaust has to be the very first, though.
Choppy idle and TPI shouldn't be used in the same sentence.
Old Jul 27, 2010 | 01:22 PM
Wd.greene's Avatar
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Re: L98 Mod Help!
thank you, i took alook and now i have an idea of what direction to go towards. i have some research to do. appreciate the help
Old Jul 27, 2010 | 06:24 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L98 Mod Help!
882 heads on a 400 is a huge mistake all by itself. Even with really good porting, big valves, and so on, they're still maybe 220 cfm at 0.500" lift. Certainly no better.
If you want to do it, then get some AFR 180 heads.
If you can't afford such heads, then just stick to a 350.
If you do buy the good heads, then plan on TPiS base and runners, 52 mm TB, ported plenum, and so on.
FormulasOnly
Jul 23, 2018 08:47 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
ssgt usaf
Sep 21, 2015 12:45 PM
