305 to 383 starter??
Old Jul 28, 2010 | 12:08 AM
383RS's Avatar
I swapped my 305 to a brand new 383 crate. When i crank it, it feels like it is tight(incorrect torque/clearences). But when i put the bottom end together it spun freely. My question is, will the starter off the 305 work with the 400 flexplate/flywheel? After a few cranks the starter gets extremely hot. I have examined the new flexplate for any tooth wear from the starter, and it still looks brand new.
Any help would be appreciated. Thanks
Old Jul 28, 2010 | 12:17 AM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: 305 to 383 starter??
what kind of starter and how much compression on the new 383?
Old Jul 28, 2010 | 12:45 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
If the starter wasn't correct it wouldn't work at all. Sounds to me like the starter was used to a smaller lower compression engine, and now with a larger and probably higher compression motor it doesn't have the power to turn it. Sometimes starters are shimed away from the block/crank, which you could probably try and see if it makes a difference. The shims can usually be bought right off the shelf at most auto parts stores, just a matter of if your starter has inline or offset mounting bolts.
Old Jul 28, 2010 | 04:22 PM
Car: 1992 Camaro RS
Transmission: WC T5
If you dig around on the internet some you will find a starter clearance checking tool. Little rod that goes in between the flywheel and starter gear. You shim the starter until the rod slides freely in between the high point of the starter gear and the low point of the flywheel ring.
Your starter is probably aligned proper. They don't usually go out. Its probably too much engine/compression to turn over.
Buy a quality gear reduction starter. That should fix your problems. You wouldn't believe how many people I've seen get 11.5:1 496's built and expect the stock starter to work. They'll barely turn the engine over.
Old Jul 29, 2010 | 04:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I picked up a permanent magnet starter for a '97 5.7 Vortec truck for my motor, which is considerably bigger than a 383, and spins in over just fine, and it is quite a small starter. Go to a parts store and ask for a starter for a '97 Chevy truck with the 5.7, they used a ministarter for a 168t flywheel. If you need for 153t ask for a '93-97 Camaro with a 5.7
Old Jul 29, 2010 | 05:18 PM
Car: 1992 Camaro RS
Transmission: WC T5
Hate to nit pick but a 5.7 vortec truck motor is smaller than a 383 at 6.2 liters. Add some compression a camshaft and a tight new timing chain and the load is considerably more.
Old Jul 29, 2010 | 06:18 PM
Air_Adam's Avatar
Doesnt matter if its smaller... it turns over my 454 (7.4L) just fine. They use a very strong starter.
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Accerrito22
Aug 23, 2015 07:22 PM
Cleotiz
Aug 22, 2015 01:54 PM
