1.6 rockers on vortec heads
Old Aug 28, 2010 | 02:25 PM
87montecarlomrc's Avatar
Ok I was wondering about putting 1.6 rockers on some vortec heads I'm goin to get. The motor is a stock 89 l98 bottom end with the stock cam. I know there's a way to multiply the cams lift (which i dont know) with the rockers or it's something like that, does anyone know for sure if this will work or how to add it up so I'll know the lift. Stock vortec heads can only go to about 470 lift so as long as it doesn't go over that I'm good right??
Old Aug 28, 2010 | 03:26 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 1.6 rockers on vortec heads
stock cam is only about 415/430, so 1.6 will be okay. But you need to check the pushrod holes. If they're slotted, get a cheap Louis tool. If they're round, drill them larger. Then have at it.
Old Aug 28, 2010 | 04:06 PM
Ok thanks I new about the pushrod hole thing but wasn't for sure what the stock cam was
Old Aug 28, 2010 | 04:23 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
You should be golden, we have an L-31 in a Tahoe with a zz4 cam in there 474/510 no problems in 6 years
Old Aug 28, 2010 | 04:26 PM
rspain85's Avatar
Just so you know, .460 is the MAX SAFE lift to run on STOCK vortecs. I've even read where guys couldnt even get .460 due to casting variations and the seals not being driven all the way on in certain years of vortec heads. Just a heads up, i'd check for clearance once u assemble the engine.
Old Aug 28, 2010 | 04:52 PM
I will have to just check it and see it they will work. I may not go that route if if it's going to be a headache, I just don't want to buy some and they not end up working right
Old Aug 28, 2010 | 11:20 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not necessarily so. I've seen some of them, right off their original truck installations, take 0.520" lift with nothing but a set of CP 98111 springs.
I've yet to find a set that wouldn't take at least 0.475", and I'm fairly certain that that's why COMP's line of HR Xtreme 4x4 cams all have 0.474" lift. They were designed and intended for L31 pickups.
Even so, .430 with 1.5 is 0.459" with 1.6. Just don't try those Crane Nitro-Carb rockers, they're really closer to 1.66:1. That'd be 0.476"
Old Aug 29, 2010 | 07:37 AM
I was wanting to just get stamped normal 1.6 rockers and like you said it adds up to be .459 lift and that's decent with a stock cam and I think the heads can handle that, do you think so? As long as I don't get the 1.66.1
Old Aug 29, 2010 | 09:21 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If your heads have pushrod slots, look at these: http://www.competitionproducts.com/E...ductinfo/6160/
but if your heads have round pushrod holes, then look at these: http://www.competitionproducts.com/E...ductinfo/6738/
Old Aug 29, 2010 | 10:43 AM
If the heads are the round hole ones, can't you just drill them out alittle, I read some post about people saying that,
Old Aug 30, 2010 | 12:46 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am running .484 lift with nothing but a spring change and opening up the pushrod hole on a set of 059s.
I have a set of 906s setup with 2.05/1.60 valves in them that run at .548" lift on the exhaust side. Those had to have the spring seats and valve guides machined.
Old Aug 31, 2010 | 12:32 AM
What springs are you using, did you have to get them machined for the new springs
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
Cameeeero
Sep 18, 2015 04:00 PM
Brendankup
Aug 30, 2015 01:46 PM
earlpote
Aug 28, 2015 10:42 AM
