V8 WIRING HELP!
Old Aug 29, 2010 | 12:44 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
V8 WIRING HELP!
its probably in this forum somewhere but i couldnt find it lol i just put a 350 in an 84 firebird (originally 2.8 carbd v6) i guess i forget how to hook up the starter because this isnt making sense.....i hooked the one battery wire to the starter the wire that is with that harness to the starter then the two little wires from the battery and the wiring harness to the starter i went to hook up the battery wire to the battery and the starter started to inguage without the key even in the ignition.....so i changed some wires did a bunch of combos same things then i had white smoke coming from the drivers side of the engine bay by the headers...if anyone can help me with this wiring im sooooo lost and i no i will have to run a wire from the fuse panel to the battery part on the distributor doesanyone know where i need to put this wire...im completely lost and cant move any farther and wanted to fire this engine today but doesnt look like it now lol
Old Aug 30, 2010 | 07:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: V8 WIRING HELP!
I'm pretty sure a haynes manual has a wiring diagram for the starter circuit on it.
Old Aug 30, 2010 | 10:57 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Re: V8 WIRING HELP!
yeah ive been looking through it and cant figure it out...but have made some progress lol i switched some wires around and got starter clicking and no more smoke, but its a brand new starter so i know its not fried, so i test it by jumping it and it worked fine with just the one big battery wire on it and i also tried another starter did the same thing so i wired it back up (this is ALL v6 wiring btw) had the big battery wire on the big wires from the harness to give the car power(which it does lights work ,etc.)the ignition wire and the small battery wire so then i tried to start it with the key...nothing no clicking no smoking so starting lol tried to jump it with all the wires same thing no action so could it be a pinched wire or what i have my negative wire grounded to the water pump for now.OH I FORGOT the smoke was happening with no wires connected except the one power wire and it looked like the brake line was heating up cuz i had nothing grounded to the block or the block grounded.
SO I GUESS MY QUESTIONS ARE LOL:
1. could this be why it was smoking cuz the block wasn't grounded?
2.if its not starting could it be a pinched wire or fuse or do i have something wired wrong? please help
thanks
-Josh
Old Sep 2, 2010 | 12:13 AM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Re: V8 WIRING HELP!
Any one have any ideas? if you think they are stupid or might be wrong say them anyway im open to all ideas cuz right now im at a stand still anyone please!!!!!
Old Sep 2, 2010 | 06:50 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: V8 WIRING HELP!
I'm sorry, I dont know if the V6 starter set up is the same as the V8. Anyone know?
Old Sep 2, 2010 | 11:16 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: V8 WIRING HELP!
http://www.austinthirdgen.org/index.php?pid=19
Starter has 2 terminals on it, one large one small. There are several wires (batt + and all fusible link wires) that attach to the larger terminal, and ONLY the purple wire attaches to the smaller terminal.
NOTE - there are NO GROUNDS that run to the starter, all the wires to starter should be hot
Old Sep 2, 2010 | 12:30 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Re: V8 WIRING HELP!
ok that helps a bit,my starter is weird lol it has 2 small terminals one close to the block and one close to theframe the the big terminal is above and centered between them, and how many fusable links are there i thought there was just the one big one(plus the batt) or do i have to run another one? and i had no grounds connected to the starter i have one on the water pump and one on the body for the batt negative wire then i have the negative wires that arewithin the harness to the back of the block
thank you for he help at least i can get somewhere now lol
Old Sep 2, 2010 | 01:41 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Re: V8 WIRING HELP!
SHE FIRES! lol i'm an idiot and had the one wire that goes to the alt on the starter...no wonder it wouldn't work now i just need it to run...then i'm golden...i tried firing it a few times got it to fire but wouldn't idle and now it sounds like the starter is hitting the fly wheel any ideas?
Old Sep 2, 2010 | 04:04 PM
Car: 1992 RS
Engine: Carbed 350
Re: V8 WIRING HELP!
Starter has to be shimmed properly - I don't remember the clearance from starter gear to flywheel - maybe someone will chime in.
Old Sep 6, 2010 | 01:02 AM
wfieldb's Avatar
Re: V8 WIRING HELP!
If i'm not mistaken the clearance is an 8th of an inch normally
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
