Emissions..?
Old Sep 3, 2010 | 01:09 PM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Emissions..?
hey, heres a pic of my 305, carb'd engine, but i hate having all these hoses on it. can any of em come off? FL has no emissions checks so its no biggie, just wondering if some can come off or be plugged up..
Old Sep 3, 2010 | 01:41 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
Re: Emissions..?
lets seee........ most of them can be removed with a change of a few parts... older carb/holley? I can't quite tell but looks like there is a vac control on the thermostat housing? (i've seen it on older ones) you could replace the housing and just get rid of all of that...
not going to drive the same especially depending on what you do...
Old Sep 3, 2010 | 02:40 PM
vinny83's Avatar
Re: Emissions..?
carb is a quadrajet..and itd affect the driving and power? damn...i hate that stuff, looks horrible.
Old Sep 3, 2010 | 02:45 PM
vinny83's Avatar
Re: Emissions..?
id really like to get rid of the cylinder thing in the front of the motor, right above the pulleys. idk what its called. and some of the hoses on it aint even hooked to anything.
Old Sep 3, 2010 | 02:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Emissions..?
That's the heater diverter valve - you can take it out - it keeps hot coolant from circulating through the heater core unless your switches are set to WARM. You just have to rerun the heater hoses taking it out of the system, and plug the vacuum line going to it.
Old Sep 3, 2010 | 03:03 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Emissions..?
Just to post it and be clear because none of us would ever officially support this. It's illegal for anyone to remove any emissions equipment from any vehicle for any reason. That said, do whatever your concience lets you do.
Old Sep 3, 2010 | 09:44 PM
vinny83's Avatar
Re: Emissions..?
srry ozz1967, didnt kno this would be a problem. illegal or not, i dont really care lol. nobody looks under my hood and sticks anything up my exhaust pipe anyways..so all good =]
Old Sep 3, 2010 | 10:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: Emissions..?
I don't personally have a problem with it and I don't represent the web site in any official capacity, but I wanted that disclaimer up there. They should make a sticky for it if they already haven't. It's your car in the end.
Old Sep 4, 2010 | 07:46 AM
vinny83's Avatar
Re: Emissions..?
ah ok. well, thx for advice guys, keep it coming, ima see what i can do about it all and keep ya posted.
Old Sep 7, 2010 | 02:35 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Re: Emissions..?
by older i mean you could get an early 70's Q jet on summit rather than that one, they have a lot less junk on them, though i did see a holley 4bbl on summit the other day with a spread bore... looked nice to me?
Old Sep 12, 2010 | 12:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are you more interested in, a clean-looking engine compartment, or a car that runs well?
You can clean up some of the stuff, but you won't make it run better by putting on an older carb and distributor.
That round thing above the water pump is the vapor canister control valve. Doesn't have anything to do with the heater or coolant.
Old Sep 12, 2010 | 12:58 PM
Car: 1992 RS
Engine: Carbed 350
Re: Emissions..?
Ahhhh - your right - I see the lines running to the carb/tb now - at first I saw the round shape and the red heater hoses, but didn't look close enough to see the two were not connected. I'd never seen one of those before.
lopezisgod
Feb 26, 2011 09:26 PM
Rauch
Oct 13, 2010 01:02 AM
jords3rdgen
Mar 24, 2007 12:23 AM
xgtharo86x
Jun 6, 2006 06:51 AM
mudaholic
Jan 13, 2002 10:06 PM
