91 rs 5.0 to 86 L98 5.7 engine
Old Sep 24, 2010 | 03:08 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
Engine: UPGRADING TO 350 5.7 L98
Transmission: 700 R4
Axle/Gears: 3.27 POSI
Doing my first swap. Just want to know if my 86 350 tpi fit in my 91 camaro rs 305 tbi?? and what changes i really need
I NEEED HELP!!!!!
Old Sep 25, 2010 | 02:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 rs 5.0 to 86 L98 5.7 engine
It will fit. You'll need the entire pass side harness, the ECM, etc. to swap the TPI in.
Old Sep 25, 2010 | 05:09 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
SO IS IT BETTER TO JUST KEEP THE ECM FROM THE OTHER CAMARO TOO. OR BUY A NEW ONE
Old Sep 25, 2010 | 08:44 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Keep the ECM from the L98 donor. Just started my LG4 carb to L98 swap today myself. Pulled TPI engine from an '87 IROC-Z.
Old Sep 25, 2010 | 10:52 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
THANKS A BUNCH MAN... AND IM GETTIN IT OUT A 86 IROC Z IM TAKIN THE REAR POSI AS WELL IS THERE ANYTHING DIFFERENT BETWEEN THE MOTOR MOUNTS.
Old Sep 26, 2010 | 10:18 AM
chesterfield's Avatar
Car: Pontiac
As a California resident are you aware that you cannot legally swap in an older motor? If you do this swap you will have to get it approved by a state referee before you can smog it. The ref will check block number and ecm number. they will also check to see if all the sensors are there for a post 1990 tpi. such as map. By the way...the Camaro data page here at tgo says that it is rumored that only 50 1986 l98 thirdgens were built. Are you sure its a 5.7?
Old Sep 26, 2010 | 04:13 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
yea i know my friend did tell me bout that i will just never be able to have it smog legit ill have to do it on the side you know how that goes... and yea i checked that too so it may have sum what of a issue they said they where made for test cars..
Old Sep 26, 2010 | 04:17 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
and as the sensor issue will i have to just transfer all the sensors over and should i buy all new ones???
Old Sep 26, 2010 | 04:44 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
350 Tpi's did NOT come out until 87... I would double check the block numbers.
Old Sep 26, 2010 | 04:55 PM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
yea its a 350 cross fire tpi 5.7L from a 86 IROC z and its going into a 91 camaro im in the process as we speak..
Old Sep 27, 2010 | 07:30 AM
ACCLR8N's Avatar
The motor mounts are the same. As for the sensors, I was able to run a scan on my donor with no codes thrown. I'm planning to use the original sensors. That said, a new O2 sensor is never a bad idea, followed by a knock sensor since its a coolant drain if you have to do it later.
Old Sep 29, 2010 | 01:01 AM
5.7 91Maro's Avatar
Car: 91 RS CAMARO
COOL THANK YOU VERY MUCH FOR ALL THE INPUT... I JUST BOUGH FLOWTECH HEADERS AND THE O2 SENSOR IS ON THE RIGHT SIDE NO PROBLEM THO... IM ALMOST DONE WITH IT ILL PUT PICS ON SOON
Cleotiz
Jan 6, 2018 08:56 PM
89gtaforsale
Aug 24, 2015 09:32 PM
TheExaminer
Aug 19, 2015 10:07 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
