vortec swap
Old Oct 14, 2010 | 04:59 PM
firehawk1724's Avatar
vortec swap
What's up fellas I have a 89 trans am 700r4.....I bought a vortec engine from a 99 tahoe...I was wondering what should I do to it to have good torque and about 350 to 400HP? DO I NEED to port the heads, buy a stealth ram or edelbrock intake etc.. any ideas and suggestion are welcome thanks
Old Oct 15, 2010 | 01:03 AM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: vortec swap
a new cam and u there really and some headers.
Old Oct 15, 2010 | 06:42 PM
Re: vortec swap
What cam should be put in? And what intake base will work for the tpi set up...figure I would use accel runners 58mm TB..what lb injectors should I use?
Old Oct 15, 2010 | 11:48 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: vortec swap
well im a carb guy, i just prefer them. not much i can tell u on tpi. to me carb is easier to work on. very simple. not as efficient but idc lol. definatly dont over carb it. get your heads ported and polished. they flow really well.
Old Oct 19, 2010 | 04:42 PM
Re: vortec swap
Anyone who can help aside from getting the heads ported and all what else should I do to this vortec engine? What kind of cam and intake combo will work on this?
Old Oct 19, 2010 | 05:29 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: vortec swap
There are ton of buildups on that exact setup. With the vortec springs, you can't cam it near what you could with a good set of aftermarket beehive springs and retainers. Are you wanting carb or tbi/tpi?
Here are two different builds:
https://www.thirdgen.org/forums/tech...c-lt4-hot.html
https://www.thirdgen.org/forums/tech...ortec-lt4.html
Old Oct 19, 2010 | 05:45 PM
Re: vortec swap
Well not sure what the difference is between tbi and tpi aside from I know what the letters stand for....I don't know the difference in performance or efficiency if that applies
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
jharrison5
Aug 19, 2015 05:53 PM
