My 305 to Pontiac 400 swap
Old Nov 13, 2010 | 12:56 PM
j dezzy's Avatar
Car: 87 TA
Ok, this is a swap I thought about doing for a long time but never got around to. Then one day I found myself in possesion of a very nice 400. Also, I'm not throwing any big money into this swap. All my big money is going into my 79 formula build. This is just to get a nice functioning pontiac 400 into my 87 TA. So here it goes...
After pulling the 305 I took the time to run new brake lines, clean, and repaint the engine compartment. Also, the mechanical fuel pump on the pontiac 400 is on the driver side, so I recommend moving your fuel line now as well. If you're going with an electronic pump it doesn't really matter.
Motor mounts. If you look hard enough you can find direct bolt in conversion motor mounts. I even posted a link somewhere on the board that I can't find anymore. But they were $90. I paid $17 for OEM replacement 79 firebird frame mounts. For the block mounts I had something lying around.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=4
I had an RW81 conversion kit that I took off an olds 403 from a 79 TA that I used the mounting brackets from and made my own engine support bar to work with the 400.
This is my support bar next to the original and the bracket
Then I bolted the OEM frame mounts to the engine mount, dropped the engine, made sure everything was level and lined up, and welded the motor mounts to the frame. By doing this the engine was actually dropped about 2 inches lower than the stock 305 location. Also, welding the mounts in place allowed me to move the engine forward or backward a bit. I moved it back to leave extra room between the engine and radiator for future modifications. Which with a pontiac motor I recommend a big radiator and electric fan since most pontiac engine (in my experience) are prone to running hot.
Transmission. I started out with a good BOP turbo 400 trans and got a hurst trans crossmember conversion kit from someone on the board. Then a buddy of mine traded me a rebuilt turbo 350 for my 400 so I butchered the hurst kit to make something that would work.
This picture is before adding gussets and cleaning it up. But I welded the extension from the hurst kit directly to the stock crossmember. Worked out great.
Other options for you trans is to buy this adapter plate from JEGS
http://www.jegs.com/i/JEGS/555/60170...oductId=751074
If your 700r4 is good just save yourself the trouble of making or buying a conversion crossmember and torque arm mount and just buy this. I wish I would have. But by the time I discovered it I already had too much invested in my BOP trans and started making stuff...
I havn't finished my torque arm mount yet so I'll get pictures and such of that up as soon as its done. But since the engine and trans is all in place it's time for the driveshaft. Obviously the stock shaft will be drastically too short so I took a stock driveshaft from a 79 TA measured up how long I needed it, about 3" shorter, I can't remember exactly. And took it to a local driveshaft shop to have it shortened and rebalanced. Cost me $60. A far cry from the nearly $400 they wanted to make a new one.
As soon as I get more done I'll add more info and pictures. If anyone has any questions or comment feel free to ask.
Here's a a picture of the engine sitting in the car after I welded the mounts down...
Old Nov 13, 2010 | 07:40 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: My 305 to Pontiac 400 swap
Very cool!
Can't wait to see more.
Old Jan 10, 2011 | 04:37 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
Looks ballsy
Old Feb 6, 2011 | 07:29 PM
TheDarkMinister's Avatar
Car: 88 Trans Am..
Engine: Hmm... 350? The guy told me
Transmission: 5 speed
I want this swap!!! My TPI just doesn't feel the same anymore at 200k miles
Old Feb 6, 2011 | 07:41 PM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
those welds look horrid man, did you even attempt to clean the metal first?
Old Feb 6, 2011 | 11:12 PM
j dezzy's Avatar
Car: 87 TA
I did actually grind the metal down clean first. I also stated that the picture was before I cleaned it up and added gussets. I used flux core. you can't make weld look pretty with that ****. lol. Plus, I'm not trying to make a gorgeous head turner. I'm just trying to make a fast f-ing car.
Old Feb 6, 2011 | 11:20 PM
Gibson's Avatar
Engine: LB9
ive only used flex core, and i used to be able to make some nice welds before my welder died (jeep accident). i cant see em that well, but it looks like your not letting the metal get hot enough and your not keeping the arc consistent along the whole weld bead. it also looks as if your not making the 'weeving' motions that create the lopsided stack of dimes look when you lay a good bead.
Old Feb 6, 2011 | 11:27 PM
j dezzy's Avatar
Car: 87 TA
I appreciate the pointers. I used MIG and TIG in auto in high school. Got this MIG/Flux core welder just to do this job actually. It was the first time I used flux core and wasn't aware of the amount of slag it leaves behind. I eventually used this welder to make repairs to my 79 formula during it's restoration. They do look a lot better by this point.
Old Feb 6, 2011 | 11:38 PM
Gibson's Avatar
Engine: LB9
no problem, just trying to help you gan an advantage over the slaggyness, the best way ive found is grind away the rust/paint/grease/mill scale where your working, but also out about 2 inches from where hte beads gonna be. i also like hobart wire, it seems to burn better than lincoln or HF (garbage)
Old Feb 13, 2011 | 02:08 PM
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
Thats awesome!!!! im in the middle of a tpi to carb swap, but i trully want a 400 or 455 in my ride! have you ever thought about putting a 200r behind that 400???
Old Feb 14, 2011 | 10:27 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Subscribed!
Can't wait to see where it ends up!
Good luck!!
Old Apr 30, 2011 | 11:40 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
This is a swap I'm strongly considering at the moment, any updates? I'm eager to see more and learn what I'll have to do when I find the right engine and get ready to swap.
Old May 2, 2012 | 10:47 AM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
after seeing how well it fit in the engine compartment, im so going thru with this, time for the machine shop!
Old Jun 3, 2012 | 09:29 PM
spdmetl's Avatar
Updates! Please...
Old Jun 6, 2012 | 04:36 PM
so are you using the stock electric pump? thats what im planning for mine, just wondering how you routed them. and how does the tranny fit up with the engine with the pointed bell housing? we NEED updates
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
st.evel07
Aug 13, 2015 06:15 PM
