question before i buy
Old Nov 13, 2010 | 06:48 PM
bear9820's Avatar
Car: 89 camaro
Engine: 89-had a 350 going for the 454 swa
Transmission: TH400 swap
Axle/Gears: ford 9" ? i think highway gears
I'm looking at an 89 camaro that had a 350 in it but is now gutted. I have a 454 from a 70's truck, and a turbo 400 trans that was in a 79 camaro. I know where im going with the motor but not sure on the motor mounts and what should be used. I have heard conflicting statements on the mounts and wonder if there is anyone who has done this that can advise me on what mounts to use.
Old Nov 13, 2010 | 06:55 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: question before i buy
Motor mounts are the same as a SB,the trans mount/crossmember to do a TH400 is either an aftermarket piece or a custom fab piece.
Old Nov 13, 2010 | 07:47 PM
bear9820's Avatar
Car: 89 camaro
good deal thanks, i did find this http://www.summitracing.com/parts/BMR-TCC024H
Old Nov 13, 2010 | 08:09 PM
Omerta88's Avatar
Car: 83 Bird
Engine: 454
Transmission: TH400
im doing a 454 th400 swap now and its way expensive more than i thought it would be
Old Nov 14, 2010 | 10:42 AM
bear9820's Avatar
Car: 89 camaro
What issues are you runnin into with your swap?
Old Nov 14, 2010 | 01:05 PM
Omerta88's Avatar
Car: 83 Bird
Engine: 454
Transmission: TH400
PM'D
Cleotiz
Jan 6, 2018 08:56 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Cleotiz
Aug 22, 2015 01:54 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
