How hard would this swap be?
Old Nov 15, 2010 | 06:36 PM
themanricky1117's Avatar
Car: 1989 Pontiac Firebird Base T Top
Engine: 305 V8 carb
hi. i was going to replace my 1989 firebird's 305 tbi engine with this new one: http://www.gmperformanceparts.com/En...case/index.jsp how hard would a swap like this be? and could i still use the same factory automatic transmission?
Old Nov 15, 2010 | 06:57 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: How hard would this swap be?
yes u could use the tranny u already have although u may want to upgrade it by installing a shift kit
Old Nov 16, 2010 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your intake manifold would have to be modified in order to bolt to the heads on that engine.
The crank is the old 2-piece rear main seal type. Yours is the later 1-piece type. Your flexplate won't fit the new engine. If you get one for an '82-'85 f-body V8 automatic application, it will fit the engine and your torque converter.
This one would bolt in http://sdparts.com/details/gm-goodwr...gines/12568758, although you may need to do some computer tuning (true with the other engine as well).
Your stock TBI exhaust will hold back any engine you install in the car.
Old Nov 18, 2010 | 09:39 PM
Engine: 305 V8 carb
i was going to get a different intake manifold and use a carb... less complicated
i dont know about the flexplate though
bamaboy0323
Sep 3, 2015 06:07 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
