95' 350 tbi swap into my 89 camaro tbi
Old Nov 25, 2010 | 05:02 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
im thinking about buying a complete swap out of a 95 chevy truck with a 350tbi,transmission and harness with only 25k miles, and swaping that seteup into my 89 camaro 5.0 tbi, can i get away with using the wiring harness thats in my camaro the stock harness?,whats the steps to make this swap work? has anyone done this before and got pics?.thanks i really aperciated your help
Old Nov 26, 2010 | 04:09 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 95' 350 tbi swap into my 89 camaro tbi
welcome aboard!
what do you have for a transmission in the car? what's in the truck?
you may have a bit more luck getting answers in the TBI forum here:
https://www.thirdgen.org/forums/tbi/
the engine side should be interchangeable, although the tune will be off. the trans side of thing may be different though.
Old Nov 29, 2010 | 11:56 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
yes thanks you.in my camaro i got the 700r4 and in the truck its got the same transmission.thanks
Old Nov 30, 2010 | 12:27 AM
TTmonteSS's Avatar
Car: 85 monte ss
Engine: 331 twin turbo
Axle/Gears: 3.73 posi 7.5"
then just get the motor and ecm. straight plug and play. you will have to do some tuning as far as the speedo goes. that will be off but everything else should work fine.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
armybyrd
Aug 10, 2015 09:23 PM
