305 to 350 swap
Old Dec 11, 2010 | 09:05 AM
Go_Bo_Go's Avatar
305 to 350 swap
I have a lot of questions so please deal with me.
I got a cheap 91 firebird that came with a 305 so i want to swap it to a 350. Is it easier to swap to a efi 350 or carb 350. Also when doing the efi swap do i need the complete engine harness out ofthe donor car or are the compatible. also since the car is a 91 there will be no emissions for it so i dont care for all the emissions stuff. i want a clean engine bay with not a lotof wireing. What are the pros and cons to swapping to both the efi and carb motor and if there is a link that has this info can you please help me out.
ed
Old Dec 11, 2010 | 09:13 AM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Re: 305 to 350 swap
ed
The EFI will be better milage and u would need the wiring .
The carb would be higher milage and u could build your own wiring harness on the engine side.
If your engine is ok, u could also just bore it and stroke it to a 350 !!???
Old Dec 11, 2010 | 04:36 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: 305 to 350 swap
Originally Posted by DAREDEVIL 1
...If your engine is ok, u could also just bore it and stroke it to a 350 !!???
I had heard somewhere that when you do that the walls end up very thin and that's why "nobody" does it. Is that true?
Old Dec 11, 2010 | 04:59 PM
Re: 305 to 350 swap
Depends on how much u bore it out !!! also depends on which 305 block u have ?!
Old Dec 11, 2010 | 05:27 PM
Davidgou's Avatar
Re: 305 to 350 swap
How about an LB9? What can you do to it?
Old Dec 11, 2010 | 05:49 PM
Re: 305 to 350 swap
I have NO clue, but i can ask my engine builder !!!!
Old Dec 11, 2010 | 05:58 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: 305 to 350 swap
ed
It would help a lot to know exactly what you have now. Is it TBI, TPI, or carb?
You do not make a 350 out of a 305 block. That is just non-sense.
Old Dec 11, 2010 | 07:32 PM
Go_Bo_Go's Avatar
Re: 305 to 350 swap
the car now has a carb 305 with a4 bone stock
Old Dec 12, 2010 | 09:24 AM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: 305 to 350 swap
since it is a 91 it has been converted to carb an efi 350 will be better on gas easier to start in cold weather in my opinion
Old Dec 12, 2010 | 03:18 PM
xcoltonx's Avatar
Re: 305 to 350 swap
if you can do a 350 tuned port/ multi port injection. youll have more control and be happier with it. might cost just a little bit more, but like i said happier. fuel eco and power in the end can be better. more hsp and torque. just saying. but cheaper and easier is the carb. just have to fab some of the stuff yourself.
Old Dec 12, 2010 | 06:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 to 350 swap
You CANNOT make a 350 out of a 305. You can make a 335, but not a 350.
You can go carbed - with that you just need to eliminate the pass side wiring harness, get a Mallory 4309 fuel pressure regulator to bring the psi down to carb level (5psi), and install a switch for the torque converter lockup if you have an auto tranny.
You can also make a 350 TBI - use all the same wiring etc. that you have, simply swap out the chip for a TBI 350 chip (like from a Caprice) and also install a knock sensor for a 350 (as I have read). No need for the fuel pressure regulator or the TCC lockup switch with this.
Old Dec 12, 2010 | 08:04 PM
Re: 305 to 350 swap
Did not know that, i have BBC in my boats..and i know u can make a 600+ out of a 454..so i asumed u could make a 350 out of a 305...GUESS NOT !!!!
SORRY
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
