HELP need some wiring help
Old Dec 14, 2010 | 10:17 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
noob here, been lurking for a week or so and decided to join. recently picked up a 91 rs that was a 305 tbi car, changed over to an hei with a carb. i would like to get rid of most of the wiring under the hood. my question is, can i just unplug the computer, pull the harness thru the firewall into the engine compartment, and remove all the wires under the hood associated with the computer? im running a block mounted fuel pump. what about the chip in the key?thanks for the help
Old Dec 14, 2010 | 11:26 AM
Pocket's Avatar
Car: 91 Trans Am
Re: HELP need some wiring help
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Dont cut the VSS wires out of the C100 or your speedo will not work
Why go carb?
Old Dec 14, 2010 | 11:44 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
Why go carb?
its already carb'd. whats the c100? are they in the computer wiring? if i eliminate all the other wires, do i still need the computer for the speedo to work?
Old Dec 17, 2010 | 12:56 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
thanks. got it working
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
