86 vette motor
Car: 1990 camaro rs
Engine: 305 tbi
86 vette motor
ok guys my buddy want to sell me his 86 vette motor, which is a crossfire setup and was out of a zr1 vette. If I do the swap can I put a tpi setup on top? and is there any difference between the 305 tpi intake and the 350 tpi intake? also if I use the tpi intake will I just use the computer for that intake?
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Re: 86 vette motor
I would do a search for the difference in intakes. Regarding the motor, there was no ZR1 in 1986 and it was an LT5 motor made by Mercruiser(in the ZR1). The ZR1 did not come out until 1990. The cross fire wasn't a bad setup but an '86 vette should not have had a cross fire in it. Hope this helps.
Car: 89 RS
Engine: 2.8
Re: 86 vette motor
I am not the brightest but I know those ZR-1 engines were Awesome. What year of a ZR-1 Covette did this engine come from? The only reason I am asking is becuase horsepower went from 375 in 89 when the first ZR-1 was announced to 405 in 1995. Those are sweet motors. It would be nice if you could get ahold of the original fuel system that came with it. Those motors were made by Mercury Outboards designed by Lotus, and you could stand a nickel on the engine, start it up and the nickel would stay standing. Great find.
I would love to see pics.
Kevin
Kevin
Transmission: 4L80E/4L80E
Many things don't add up about what your bud is claiming. Your first reaction when hearing "Corvette" should be skepticism.
'86 Vettes were all TPI. The differences in TPI, regardless whether Vette or f-body, were due to the model year rather than the engine size (with the exception of the injectors - 305 had 19 lb, 350 had 22 lb all years). Well, '86-1/2 & up Vettes also had aluminum heads, which required external plumbing for the EGR source for the exhaust gases.
Car: 1990 camaro rs
Engine: 305 tbi
Re: 86 vette motor
Sorry that is a mistake on my fault i was thinking z51, with all the performance goodies, but typed zr1. And the engine i believe is rated at 280+hp? I may be wrong on that but it will be getting rebuilt before the swap regardless. Which also is in debate. Just doing some research first.
Car: 1990 camaro rs
Engine: 305 tbi
Re: 86 vette motor
p.s. it may be an 84 not 86...sorry might be confusing my years
Car: 1990 camaro rs
Engine: 305 tbi
Re: 86 vette motor
I was wrong just asked and it is a 84 vette, not an 86. sorry for the confusion, but does anyone know if i can use this intake?
You can put a TPI intake on a Crossfire engine. '87-up f-body TPI base had the center two mount bolts at 72 degrees, while the Crossfire engine will have all of the bolts at 90 degrees.
The stock Crossfire was more like 205 HP.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
