How much to mill vortec heads?
Old Feb 12, 2011 | 09:24 AM
greenturtle05's Avatar
Need a little help. I need to know how much will i need to mill a set of vortec heads, on a 350 with flat top pistons,and stock head gasket for 10:1 compression?
Old Feb 12, 2011 | 10:11 AM
skinny z's Avatar
Re: How much to mill vortec heads?
10:1 is possible without milling. With a true flat top piston that has a valve relief volume of about 6cc, the 64 cc (assumed) chamber will yield 9.89:1 also assuming a piston below deck of .025". That's using a .025" gasket. Put a .015" shim gasket in there and you get 10.14:1.
Old Feb 12, 2011 | 10:44 AM
whats the thickness of the stock head gasket? also i already have the heads milled .010. what should my compression be as of now? i was thinking about taking another .010 off when i get my springs installed.i cant remember the piston valve relief cc.
Old Feb 13, 2011 | 08:05 AM
skinny z's Avatar
You'll have a prety hard time figuring out if you have 10:1 if you don't find the data needed to do the calcualtions.
A .010" milling of the heads will shrink the chamber about 1 -2 cc's.
I couldn't tell you what the thickness of the stock head gasket would be. I'd only be guessing. You should also find out what the valve relief volume is. Without it, you'll never know what the CR might be.
Old Feb 13, 2011 | 03:58 PM
found the info on the pistons http://www.jegs.com/i/Sealed+Power/844/L2256F/10002/-1
Old Feb 13, 2011 | 05:33 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Here you go, play with this and youll get closer.
(sounds bad, huh lol)
Youll find cc in pistons makes the biggest difference in the compression not the deck height but if they are already installed probably the most expensive/most work lol.
Youll need to know the exact CC in your combustion chamber that will help. I can show you a real easy and cheap way to do that if you like. You can also figure intake runner volume etc without having to spend 120 on a burette. Its pretty accurate, within 1 cc or less
http://www.rbracing-rsr.com/compstaticcalc.html
When choosing pistons read the mfrs footnotes if they dont show them ask
Some will rate the c.r. at 0 deck, some at .025 in the hole, etc.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
