Blueprint engines??
Old Feb 13, 2011 | 08:30 PM
jtrice02's Avatar
Car: 86 irocz28
Engine: 350 tpi
Blueprint engines??
Im looking into some new 350 crate engines for my 86 camaro. I came across one by Blueprint engines.....i was wondering if anyone has any experience with these and what their opinion is on them. this is the exact product number and the link to jegs with the item listing...also if anyone has a suggestion for what else i could put in there im looking for 300+ hp crate for around 2k
Blueprint Engines BP35511CT1 - Blueprint Engines SB-Chevy Budget Stomper w/Cast Iron Heads 355ci/ 310HP/ 360TQ
http://www.jegs.com/i/Blueprint-Engi...11CT1/10002/-1
Old Jul 20, 2011 | 03:10 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Re: Blueprint engines??
Bump.. Got same question.
Old Jul 20, 2011 | 10:01 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I've read some pretty bad things about Blueprint. Do a search and you will find some stuff about them.
Old Jul 20, 2011 | 10:34 PM
87irocftw's Avatar
Car: 1987 Camaro Iroc Z
Engine: 327
Transmission: Soon to be Muncie 22
They seem to screw a lot of people over.
Old Jul 20, 2011 | 10:44 PM
BleedOrange's Avatar
Car: '85 Z28
Engine: 463 BBC
Axle/Gears: 373 with an Eaton posi
Old saying goes you get what you pay for. I would build one if it were me 300hp isnt hard at all to achieve a decient set of heads will get you real close on a stock 350. you can find 350 block cheap too at wrecking yards. then a rebuild kit for a 350 is around $400 or so then a set of summit brand heads arounf $600 and shoot man you dang near there and you know what you got cause you built it.....thats just me though I have never personaly bought a crate engine
Old Jul 22, 2011 | 12:36 PM
hartsmike's Avatar
Axle/Gears: 273
Thanks Orange... I don't have the knowledge to be a mechanic much less build one that's why I'm out searching but it sounds like to me that it shouldn't be that expensive.
Old Jul 22, 2011 | 01:10 PM
brewer1862's Avatar
Car: 1990 rs, 1989 rs
Engine: 383 blueprint crate, 305 tbi
Transmission: 700r4, t56
Axle/Gears: 3.73, 3.23
i have the 383, aluminum patriot heads, blue print engine.. bought the non-dressed one, runs great for me? havent had any problems, YET. crossing my fingers haha.
Old Jul 22, 2011 | 02:19 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
just an idea. check with your local auto repair shops see if they can recommend a shop.
Old Jul 22, 2011 | 02:25 PM
jamieschott's Avatar
Count another to the screwed column by this company. 383 crate with 3500 miles broke a rod. Claim denied due to " lack of lubrication" and they want me to pay freight to have engine sent back to me.
Old Jul 22, 2011 | 03:32 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
probably cheap chinese
Old Jul 22, 2011 | 03:36 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
I just noticed you live in Louisville,KY. these guys are great engine builders. road trip
http://www.ohiocrank.com/
Old May 7, 2016 | 07:54 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Any updates
Old Jul 1, 2016 | 03:52 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Blueprint engines is used by many of the big automotive tv shows on velocity and even hotrod tv and the road kill guys from hotrod magazine. They get great reviews from them and I'm running a 383 built by them and it runs great.
Old Jul 3, 2016 | 02:49 PM
KITT1983's Avatar
will it work with my crossfire injection ?
Old Jul 3, 2016 | 06:16 PM
Car: 1986 IROC Z28
Yes, you can buy the engine with out the intake on it and bolt your intake and cross fire injection system on it, but the cross fire injection system is not going to support much more than a stock engine.
Old Jul 4, 2016 | 02:15 PM
KITT1983's Avatar
my cfi setup is not stock and there site says the motor does not support pollution controlled vehicles
Old Mar 23, 2017 | 11:03 AM
VickK's Avatar
Car: 88 Bird
Engine: 305 TBI
Axle/Gears: Stock
Looking through my latest jegs catalog and for the life of me I don't see how a blue print 355 sbc (BP35511CT1) rated at 310 hp and 360 ft.lbs tq. and their 383 (BP3832CT1) with exact same output and identical specs(other than the extra cubes and extra $300). Anyone ever catch this. Any gear head has to scratch their head on this one.
Old Mar 23, 2017 | 01:28 PM
Twin_Turbo's Avatar
Did a build for a friend who bought an all forged short block from blue print. Had problems after a few miles. Took it apart. Major scored walls. Broken (when installed) rings. Cam keyway off by a couple of degrees. Had a hell of a time degreeing the cam. Major pos
Old Mar 23, 2017 | 02:30 PM
Car: 1986 IROC Z28
When was this? What did the company do to make it right?
Old Mar 23, 2017 | 03:42 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
I bought my 355 from blueprint after breaking the motor in went to autocross event an I over revved the motor broke a rock arm.pulled the valve cover off took pics called them an talked to them sent me new rockers guides push rods.told me sorry for that happening to let them know if anything else was damaged an they would take care off it haven't had one problem after that..buddy of mine runs the same motor not one problem.know 2 other guys have motors from them also no problem..don't want to sound like a d@#$ but might be user install problem that people are having with there product just saying
Old Mar 23, 2017 | 04:11 PM
Twin_Turbo's Avatar
Couple of years ago.
Since we're in europe we just chalked it up as another example of overpriced pos syuff companies sell. Completely redid the engine and no problems so far
Old Apr 8, 2017 | 08:31 PM
silvvette's Avatar
jtrice02, i was going go buy a Blueprint also. Did the research and found a lot of negative. I called blueprint and asked about their policy, was shady.
went with an lt1 from a 96 vette. Well worth it and Way way better.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
