Would 92 camaro 305 fit in 84 camaro
Old Feb 14, 2011 | 02:06 PM
JJs84Berlinetta's Avatar
Hi,
First time poster so take it easy guys, I have a 84 Berlinetta with a vd and automatic tranny. I found a good deal on a 305 from a 92 Camaro RS. Question is would that 305 mount up in my 84? Would the wiring harness be a problem?
Old Feb 14, 2011 | 02:30 PM
Blue1990camaro's Avatar
Re: Would 92 camaro 305 fit in 84 camaro
ur gna need to either get rid of the TBI and go back to carb, or ur gna need a wairing harness and computer, and no the v8 will not bolt up to ur v6 tranny,
Old Feb 14, 2011 | 02:31 PM
I knew I would have to get another tranny any suggestions? What i meant was would it mount up on the motor mounts.
Old Feb 14, 2011 | 02:36 PM
no ur gona have to change ur motor mounts and MAYBE trans mounts, i sugest a 700r4 outa another camaro for ease of instalation and a set of SOLID motor mounts, if u want ur car to shake lol if u want comfort go with factory
as far as harness, if u dont wana mess with a computer grab an HEI distributor and a carb and intake setup fo ur choice and shell run just fine
Old Feb 14, 2011 | 02:38 PM
Sounds awesome I want to stay with carburated, this may be a stupid question but a SBC would work. Right?
Old Feb 14, 2011 | 02:42 PM
a 305 is a SBC, SBC means small block chevy, and yea personaly i stick with sbc not bbc (big block chevy) shorter stroke engines are more fun to me, i have a 85 Z25 with a 305 TPI in it and love it, its no where near fast enuf for me tho, its forsale
Old Feb 15, 2011 | 08:13 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
If you want to make it cheap and good for SOME power abuse, I recommend the 700R4 (4 speed auto) or TH350 (3 speed auto). Both are great transmissions when beefed up in the right spots. Stock they can handle moderate power if you don't abuse it every second of the day.
Also - get a GOOD transmission cooler.. none of that cheap junk. Heat kills transmissions.
Old Feb 16, 2011 | 12:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you are going through the trouble of a swap for a V8 engine anyway, get a 350. 350's are the just about the same price as a 305 just about everywhere in the world. Crazy to go through all that and have less than you could have had.
And get a 700R4 tranny from a 1988 - 1993 F-body car - they made significant changes to the 700R4 in mid year 1987 that makes it better/stronger. Also, ONLY one from another F-body car is going to have the torque arm mount on it.
84z96L31vortec
Aug 20, 2017 12:16 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Wvcamaro
Sep 4, 2015 08:38 PM
matthew911
Aug 12, 2015 09:38 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
