2.8L V6 to 4.3L Vortec V6
Old Feb 21, 2011 | 09:54 PM
berlinettaman's Avatar
Car: 1983 Camaro Berlinetta
Engine: 2.8L Carb V6
Transmission: 5-Speed Manual
Axle/Gears: Stock
I have an '83 Camaro Berlinetta with the 2.8L V6. I'd like a little more out of the car and am wondering if a 4.3L Vortec V6 will squeeze into the engine compartment/fit the stock transmission (5-speed manual). I am hoping to drop the Vortec in with the stock transmission. Please help, need advice!
Old Feb 21, 2011 | 10:41 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: 2.8L V6 to 4.3L Vortec V6
The 4.3 won't bolt up to the stock tranny. It uses the same bolt pattern as a V8 I believe.
Old Feb 22, 2011 | 07:12 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
yep, the 4.3 has the same bolt pattern as the 350. It wont bolt to your existing transmission.
As far as fitting, it will easily fit. It is smaller then a sbc and they came in these cars. Big Blocks will even fit in these cars.
Old Feb 22, 2011 | 02:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You will have to custom fabricate mounts for a 4.3 V6. Although it is basically a 5.7 with two cylinders missing, they moved the engine mounts relative to the bellhousing on the 4.3.
Jared11
Feb 9, 2022 11:18 AM
Renier
Nov 9, 2014 04:58 PM
Jesse1994
Aug 31, 2013 10:44 AM
stepover2
Jul 10, 2006 10:02 PM
