measurements for a v6 to a v8 swap
Old Feb 25, 2011 | 01:34 AM
masterchin123's Avatar
Hey iv taken out my 2.8 v6 from my 1989 pontiac firebird and I'm puting in a 305 v8 but there are no motor mount holes on the crossmember for the v8. So I was hoping someone would have the measurments I need to drill the holes for the v8 motor mounts and would be willing to pass them on to me?
Old Feb 25, 2011 | 11:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: measurements for a v6 to a v8 swap
They should be there - I'm pretty sure all the crossmembers are the same, and all got punched for either motor - I can't imagine that an automated plant would set up double the machining tools when there is no need. Look again, should be forward of the V6 holes no more than a few inches. Probably filled with undercoating, road grime, etc.
Old Feb 25, 2011 | 02:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Look in the "V6 to V8 swap" sticky in the top section of this forum. There is a picture of the V8 mounts on a stock crossmember. The bolt holes you need are there.
Old Feb 28, 2011 | 06:18 PM
Ok thank you
87v6Bird
Jul 1, 2018 04:12 PM
z28cdoyle
Aug 21, 2004 12:25 AM
Mongoose
Apr 25, 2004 06:27 PM
Z-Monkey
Apr 5, 2004 06:52 PM
Streetiron85
Mar 11, 2003 08:26 PM
