fuel pump question
Old Mar 1, 2011 | 01:50 PM
auditech09's Avatar
fuel pump question
hey guys, swapping an 84 carb'd 2.8 for an 87 mpi 2.8, anyone know of the specs i need for an inline (external) electric fuel pump to use so i don't have to drop the tank?
Old Mar 1, 2011 | 03:06 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: fuel pump question
I believe stock psi on that is around 65-70 or so. However, you still need to drop the tank to remove the old fuel pump. Hooking up an external pump without removing the in-tank pump will put too much of a strain on the external pump and kill it.
Old Mar 1, 2011 | 03:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1984 carb car shouldn't have an in-tank pump just a carb pickup, so shouldn't be any issues there.
Old Mar 1, 2011 | 03:30 PM
auditech09's Avatar
there is no in tank pump on the 84, it has a mechanical pump on the side of the block, the specs i found say for key on engine off: 40.5 to 47 psi and for key on engine running: 30.5 to 44, does this mean a 50 psi pump would be fine?
Old Mar 1, 2011 | 03:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Oh, I thought the carb'd V6's had an in-tank pump. I knew the V8's had theirs on the block.
In that case, an inline pump will be fine. 50 psi will work with a regulator of course. You should be able to use the stock one I would assume. If you plan on doing any performance mods in the future you might want to go a bit higher.
Old Mar 1, 2011 | 03:43 PM
auditech09's Avatar
i don't plan on doing anything for performance on this engine i just want the benefits as far as driveability from fuel injection, thanks for all your help guys, now anyone know where i could get an inline pump for cheap?? lol
Old Mar 1, 2011 | 03:57 PM
Car: 1992 RS
Engine: Carbed 350
Hmmm - I didn't notice the V6 part - maybe they did have an intank pump, I have no idea about that. IF there is one, then you'll have to remove, in which case might as well just install the correct internal pump for that engine. If not, then you should be able to just use an external electric.
You'll have to order from somewhere, I'd check summit or Jegs. But I don't know what pressure you need.
Yikes - I'd never swap out a V6 for another - for the same trouble of the swap I'd do V8 350 minimum.
Old Mar 1, 2011 | 07:34 PM
auditech09's Avatar
i need it as a daily driver so v6 will save me on gas for now...trust me i'll be dropping a v8 in it eventually but the 73 Charger is my only v8 car for now
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
