350 Tpi Help
Old Mar 8, 2011 | 04:02 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
350 Tpi Help
ok im still undecided in buying a motor and need ur opinion on this and maybe some help ....im thinkin of buying a 1988 corvette motor tpi with aluminum heads it comes with ecm but i did some research and found out that that model year comes with the vats key and that motor is going in a 1986 trans-am if i were to get this motor how would u by pass the vats key and second the a/c pump looks diferent and the routing of the hoses is diferent, my next question is if i would be better of with a iroc-z or trans-am gta motor i know for 1989 they had vats key and would run into the same problem on how to by pass that but what would u recomend the vette motor or a trans-am gta or iroc-z motor both are the same please help me out with this
Old Mar 8, 2011 | 06:16 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: 350 Tpi Help
As far as the VATS, it can simply be turned off in the PROM. I have also heard of people using a resistor to "bypass" it.
You will find a ton of information searching. There are many people running vette L98's here.
Old Mar 8, 2011 | 09:44 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 350 Tpi Help
You don't have a VATS module in your 1986 car, so you cannot use the "resistor" method. BUT - you can buy a VATS bypass module from ebay, PAinless, etc. - like $20 - $50. It generates a signal that you connect to the ECM from that vette so that the ECM will fire the fuel injectors. So that's not an issue.
Your 305 accessories will bolt right up to that vette 350 motor, so no issues there either - just use your a/c, smogpump , water pump, p/s pump (if the vette stuff doesn't fit under hood, which it should).
Old Mar 8, 2011 | 11:38 AM
DiabloWS6's Avatar
Re: 350 Tpi Help
ill look up that box i think i saw one on hawksthirdgenparts
Old Mar 8, 2011 | 05:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 Tpi Help
http://www.bakerelectronix.com/products_vats/
http://www.fieroaddiction.com/passkey.html
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
