87 TPI 350 replacing 85 305 TPI
Old Mar 25, 2011 | 05:24 PM
manifoldsrme's Avatar
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
I am going to be replacing my LB9 305 tpi engine in my 85 IROC with a stock 350 tpi from an 87 IROC. My question involves the distributor. I believe I need to replace the distributor gear with a melonized one as I am going to be reusing the distributor from the 85. I s this correct? I am assuming the factory roller camshaft is steel in 87? Any input is appreciated.
Old Mar 26, 2011 | 06:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's the word from GM.
I've heard that they started using the melonized gear before they started using roller lifters, but I can't back that up. I believe the gears will swap between the distributors if you're getting the '87 piece. But, I can't say that for certain.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
