Carb engine needs to be a TPI.
Old Mar 26, 2011 | 06:49 PM
Hunter0075's Avatar
Car: 91camaro Rally, work in progress
Engine: 5.7 350. 400hp 400ftlb torq
Transmission: turbo 350
Axle/Gears: stock rs rear, 3.23.
I have a engine which has a carb. I need to make it it fuel injection. Can I use a complete intake from a 90-92 camaro or trans am? I take it I need to use new heads which are fuel injection. I know the stock one's will not work. I have a cam in the engine now. I see that hawks thrid gen or youngs fbody has a programmer to comp for the cam. Trying to do my homework so I can get the car running. thanks
Old Mar 26, 2011 | 07:14 PM
jwallace's Avatar
Car: 1985 IROC / 1986 IROC
Engine: LB9 (85) / 383 (86)
Transmission: 700R4 IN BOTH
Re: Carb engine needs to be a TPI.
Depending on what heads are actually on the car now and what cam is inside. Is it the 91 that is in your info that is listed as a work in progress, if so, is it the original engine that someone put a carb on. A 91 that wasn't TPI would have been TBI, so may be easier than you think to get it back to EFI.
Old Mar 26, 2011 | 07:46 PM
Hunter0075's Avatar
the cam is a comp cam 292I/292E duration .501 intake/.501E rough idle. i the heads are 2.02i/1.60E heads 9.8:1 comp ratio
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
